Page 1 of 3 123 LastLast
Results 1 to 25 of 59
Brake issues
    Lifer Pittenger5's Avatar
    Austin
    Brake issues
    Well, if you were at the track this weekend, we've probably gone over this, but nothing was solved.
    So all weekend, I was dealing with some strange brake problems. The brakes would be 100% going into the bowl, by the time I made it to 9, when I touched the brakes, the lever would come all the way to the bar, then the next pull would be 100% again. This would ONLY happen in turn 9, and it was at least 75% of the laps. It got to the point I was purposely touching the brake earlier to reset the pads before I needed to actually scrub some speed. (and yes, I know Im a big pussy for braking in 9, thats something no one can help me with) We changed the master and it was still happening, so its not the master. The first thought everyone comes up with is a bent rotor, but its the exact same corner every time. Never had much of a problem anywhere else. The next thought is being leaned over, hitting the bumps and stuff, but with the chicanes you flick the bike around a lot more, and never had a problem into 3 (thank god). So I dunno, I have no other guesses. Anyone have any guesses or better yet, solutions?
    Zip Tie Alley #505
    Senior Member FTMS's Avatar
    Warren, NH
    Re: Brake issues
    Check the rotor for being warped and the wheel for play. Either one of those could move your brake pads out enough that you need an extra pump of the lever to get them back to a point that one pull will squeeze them. Also check the caliper pins (if it has a floating caliper) and make sure the caliper will move as it is supposed to.
    2004 Honda VTR
    1998 Honda VTR (Track Bike )
    1990 Honda CB-1
    1973 Yamaha RD350
    http://www.ftmsnh.com
    Meriden, Ct
    Re: Brake issues
    Turn 9 is possessed... That's the only answer.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Re: Brake issues
    Yea I was going to say wheel play or something like that too, but even that doesn't make much sense if T9 was the only corner. Might it have something to do with the head shake over T8?
    quit braking in T9 anyway...
    Austin
    Re: Brake issues
    I am a huge vagina. But yah, I get decent shake in 7, but I do in 4 over the hill and stuff too, not as bad though. I even went out of my way to miss the bumps a few times and it still happened.
    Zip Tie Alley #505
    Jun 2005
    Re: Brake issues
    Daniel's bad brake Ju-Ju jumped from his bike to yours at some point?
    Austin
    Re: Brake issues
    DONT YOU PUT THAT EVIL ON ME TRICKY MIKE! Don't you put that on us! You are NOT paralyzed!
    Zip Tie Alley #505
    Jun 2005
    Re: Brake issues
    Didn't mean to harsh your mellow, brah
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Brake issues
    Richie, this is basically what my vmail said too.. wheel shake.
    Posted by Jane in BoxChat
    Austin
    Re: Brake issues
    I figured it was that, but why am I the only one having this issue? And how can I fix it.
    Zip Tie Alley #505
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Brake issues
    Are your spacers correct? Wheel bearings ok?
    Austin
    Re: Brake issues
    I hope so ...
    And I would hope so ...
    Is tehre a way to check either
    Zip Tie Alley #505
    Westford, Ma
    Re: Brake issues
    With the bike on a stand and the forks secure. ( maybe someone holding them steady ) Grab the front of the wheel, shake and make sure there is no movement. Aside from rotating on the axle there should be no wiggle, shimmy, sideways movement at all. EVEN a very little movement is enough to walk the disk pucks back into the caliper.
    Re: Brake issues
    Austin
    Re: Brake issues
    So then next week I will post up, and now in 11 I need to grab the brakes twice. But I tell ya, if I can keep this pattern up and just not use the brakes Im gonna be faster than Jeff!
    Zip Tie Alley #505
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Brake issues
    I do not see how a wobble puts air into your brake system.
    Canterbury, NH
    Re: Brake issues
    It could compress the pistons in the caliper so the pads aren't up against the rotor the way they should be. Kinda like how you have to pump pressure into the system again when you put the rim back on.
    Re: Brake issues
    +1
    it's not that air is getting in the system, the rotors are somehow pushing the pads back into the caliper.
    Worcester, MA
    Re: Brake issues
    +1
    to ECK #187
    LRRS EX #165 (formerly)
    thanks...... Mark.....
    Re: Brake issues
    that is some serious wobble to do that. Wow! I guess I learned a thing today. Now what? A stabilizer?
    Lifer obsolete's Avatar
    Norf Sho
    Re: Brake issues
    It's not the bad wobble that's the problem. The wobble is what is allowing the problem to be seen. It should be able to wobble and not do this. There is a bad part that is allowing the wobble to torque or shake a part that creates a non linear spin of the rotor therefore pushing towards the pads and causing the piston to retract into the caliper.
    The wobble is just the catalyst, get rid of the wobble the problem would still remain.
    -Alex
    Austin
    Re: Brake issues
    I even changed my line in practice and it still happened.
    Zip Tie Alley #505
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Re: Brake issues
    Rotors float ? so check attachment hardware.
    Don't do anything until you have cleaned the f out of them with rags and brake clean
    Even clean then lightly break the surface of pads and rotors with emery etc swirl.
    Flush the brake fluid throug the system if it has high water content it can boil then condense woooo wooo woooo
    Glen Beck is John the Baptist
    Re: Brake issues
    Also Note that the Rotor and Caliper are both brand new.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
  1. Replies: 0
    Last Post: 02-27-12, 10:34 AM
  2. Front brake lever microswitch + brake bleeding
    Last Post: 05-05-11, 07:52 AM
  3. Duc Monster rear brake issues
    By Doc in forum Bike Maintenance
    Last Post: 06-28-08, 12:20 AM
  4. front brake issues??
    By FireFly in forum Bike Maintenance
    Last Post: 06-28-06, 06:01 PM
