Quote:
PC,
Your symptoms are classic idle mis-adjust.
With idle mixture screwed all the way in, turn it about
1 1/2 turn out and start the bike. (Of course after you have verified the valves have 4-5 thou clearance when piston at TDC) Raise the slide with the Idle speed screw for a fast idle. Then, screw the idle mixture screw in till engine speed falters than back out till it falters. Split the difference and then re-adjust the idle speed screw for a comfortable idle. If the idle mixture screw doesn't have enough range to find the lean and rich faltering points, you need a different idle jet. I think stock is a 60. By the way, the idle speed screw is the big one with a spring around it along the centerline of the slide and the mixture screw is forward just behind the neoprene sleeve clamped to the carb. Screw out for richer, in for leaner.
The possible air leaks are around the neoprene manifold clamped to the carb or the joint between head and manifold flange sealed with an "O" ring.
:thumbsup:
