Results 1 to 25 of 25
Carburator question
    Braap Baggey22's Avatar
    Westford, VT
    Carburator question
    I have a 2008 Kawasaki ZZR600 with 6,050 miles. It's mostly stock except for a Yoshi slip on.
    It's having this habit of a wandering idle when it's warmed up. When I'm sitting at a stop sign or stop light the idle will raise to around 3000RPM and stay there. Also if I rev the engine it doesn't immediately drop back to idle like it should, it slowly goes back down the rev range until it gets to idle. Trouble is it revs fine throughout the range while riding.
    I've had two ideas for the problem. One person said the jetting is off because of the slip on exhaust can (running too lean on stock jets), the other suggestion was something to do with the butterfly valves sticking.
    Anyone here have different suggestions/ideas? Thanks
    Donny says vacuum.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Carburator question
    Donny says vacuum.
    The butterfly's or slides could be sticking as well.
    Posted by Jane in BoxChat
    Westford, VT
    Donny says vacuum.
    Vacuum...... How do I check for a vacuum leak?
    How can I remidy that?
    Just Registered Doc's Avatar
    Jericho, VT
    Quote Originally Posted by Baggey22 View Post
    Stop by the house with it this week.
    Docs gonna teach them to suck properly.
    Jericho, VT
    Lots of wd40 and a screwdriver.
    Westford, VT
    When is you free??
    I need to Pee! MellowYellow's Avatar
    Aug 2010
    Chicopee
    Baggey 1st check the A/F mixture screws. Just had the same problem on my Gixxer. 3 carbs were 3 & 1/2 turns out the 4th was 2& 1/2. Set them at 2 turns out and no more 3K idle when warm.
    K8 GSXR 600
    Westford, VT
    Yea, that's also something to note. It'll only wander when the bike has been warmed up.
    Lifer markbvt's Avatar
    Georgia, VT
    It's too lean. Bikes are jetted lean from the factory due to emissions regs. Introducing any changes to the intake/exhaust system to increase flow makes it even leaner (as has been done to yours with the slip-on pipe).
    Happen to know if the previous owner made any carb adjustments at all? Pilot screw adjustments, anything?
    --mark
    Aug 2010
    Chicopee
    Mine only did it when warm also. 160 +
    K8 GSXR 600
    Sep 2007
    Hinsdale, nh
    bike is running lean you will need to fatten it up a bit
    many a biker have been ruined by a wife and a full time job
    Westford, VT
    I am unaware of any adjustments by the previous owner.
    Jericho, VT
    I am free all day. Unemployed.
    Georgia, VT
    There probably weren't any... and as a result your bike's running too lean.
    We can make a partial change by adjusting the pilot screws and shimming the needles to richen up the midrange a bit. But that won't help at full throttle.
    Want to plan some time this weekend to look at it?
    --mark
    It's "carburetor"... Which could be your problem to begin with
    CCS/LRRS #83
    Jan 2010
    cny
    doesn't opening an exhaust make a system go richer?
    my first thought was sticking slides
    Majer:Danjer™ ChicknStripEatr's Avatar
    Sep 2005
    RI/NH
    Baggy, before you go tearing your bike apart, check the choke cable. On my older model ZX-6R (same as your ZZR) the choke cable would occasionally seem as though it would hang up causing the idle to rev slightly. There is an adjuster on the cable, try backing that off 1st.
    2nd, for the bike down revving (this is going to sound dumb) does your throttle grip rub ever so slightly against the bar end? I had to shave the stocker grip slightly with a razor blade.
    I get offended by people who cry they've been offended
    Georgia, VT
    Quote Originally Posted by gamorg02 View Post
    No. Leaner.
    --mark
    Jan 2010
    cny
    No. Leaner.
    --mark
    i found running smaller mains on my vmax when i had a slip-on helped more, and the more restrictive mufflers (cobra) needed larger jets. is the v-max different or do I have it backwards.
    obv opening up the intake leans it out yea?
    Lifer obsolete's Avatar
    Norf Sho
    The less restrictive you make an engine (intake/exhaust) the more O2 is introduced into the combustion chamber. If the fuel metering is at a fixed amount then you have more O2 and the same amount of fuel and therefore a leaner condition than before.
    -Alex
    Westford, VT
    I'm gonna go for a ride and then pull a plug (or 4) and see what the plugs will tell me.
    Quote Originally Posted by ChicknStripEatr View Post
    I'll check the choke and bar end while I'm there.
    Westford, VT
    UPDATE!: So I went over to Doc's last night and put new jets into the ZZR as well as a new K&N air filter. I only rode home from Doc's but so far the bike is running MUCH better. There's a little more midrange and high end response. I did get it up on the highway once we were done and checked smoothness throughout the entire rev range and it seems to be great! I'll know more once I ride it more.
    Jericho, VT
    Glad I could be of service.
    I would have liked to tighten the carb boots up some but other than that everything looked good under there. Carbs were clean, no sticking slides etc.
  1. 125 question
    By gixxer72 in forum Dirty Bastards
    Last Post: 02-27-13, 10:34 AM
  2. Replies: 13
    Last Post: 06-30-09, 12:49 PM
  3. Question
    By Crash Dummy Denno in forum Pit Area
    Last Post: 09-27-07, 06:30 PM
