Results 1 to 8 of 8
Ducati 900SS Jets
    Roslindale, MA
    Ducati 900SS Jets
    Does anyone have any firsthand experience with Dynojet and Factorypro jets? which ones work better on the Ducati 900??
    Thanks!
    Jun 2005
    Re: Ducati 900SS Jets
    No direct experience with the Duc, but having used both several times I've had much better luck with Factory Pro... great tech support, too.
    Lifer BostonSVkid's Avatar
    Dec 2005
    So you spent all that doe on having your bike worked on now you are going to go messing with it again?
    2006 Ducati Monster S2R800
    Roslindale, MA
    Listen Homer, I was just askin a question. There is a small flat spot when you roll on at 5-6k. I want to get that fixed. Right now I just threw together the jets from what I had, and what I was able to get from Doc. :p
    Jun 2005
    Is it better/worse when it's hot vs cold?
    Are you talking 5-6K at WOT?
    Dec 2005
    Quote Originally Posted by DesmoTull View Post
    Nice man. SO how did it pull at VIR?
    I actually have the same exact flat spot on the SV so scotty is going to find me someone to fix it.
    Roslindale, MA
    Quote Originally Posted by trickphoto View Post
    When it's fully warm at WOT, yes.
    I found this on the Factorypro website. Should be fairly easy as long as I have a good long sunny day and can take the bike out a bunch of times after changing things around.
    CV Carb Tuning Procedures
    Jun 2005
    Yep... kind of the nature of the beast. Their instructions are pretty much spot on. and if it's running reasonably well now you're ahead of the game. Make sure your mains are right first... I'd look to change needle clip position, but (ideally) you'd want to know if that flat spot is rich or lean. After that it's a long-drawn out process of change one thing at a time, test, change one thing, test again.
  1. For Sale - Motorcycles | 1996 Ducati 900SS
    By whynot in forum For Sale
    Last Post: 04-23-21, 03:09 PM
  2. Ducati 900SS ie
    By SquadraCorse in forum For Sale
    Last Post: 12-01-13, 03:16 PM
  3. 1997 Ducati 900SS/CR
    By tig720 in forum For Sale
    Last Post: 07-24-11, 09:39 PM
  4. Ducati 900SS/SP (NOT MINE)
    By DesmoTull in forum For Sale
    Last Post: 10-25-09, 08:18 PM
  5. 99 ducati 900ss
    By roadracer685 in forum For Sale
    Last Post: 10-26-07, 11:49 AM
