Results 1 to 25 of 37
Chain lube?
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Chain lube?
    I was curious what you guys are using. I usually clean it with wd-40 then use chain wax but i want to try something different..
    Posting Freak senecak19's Avatar
    Massachusetts
    Chain lube?
    I use VP Chain Wax. I've used the Motul product and Maxima product in the past... they all seem to work pretty well.
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Chain lube?
    Maybe i'll try the motul lube. I use their Motul E-Tech oil in my bike and like the way it shifted after i started using it..
    Lifer Karaya One's Avatar
    Springfield, Mass
    Chain lube?
    I run E-Tech in my Strom. Nice stuff and priced right.
    Try Motorex 622 Strong. Best chain lube I ever used.
    Check out my eBay store!
    Dave - Motorace - Michelin
    Lifer Punjistick's Avatar
    Norwell, MA
    Chain lube?
    Anybody ever try that dupont teflon lube? I haven't used it myself but I have heard it works wonders.
    Mar 2007
    Chain lube?
    Quote Originally Posted by zxme View Post
    I may be wrong but I thought wd-40 was bad for the o-rings and not recommened.
    I use Kerosene to clean my chain then I just lube it with Suzuki chain lube.
    This seems to do the trick for me, however I did hear good stuff about the Dupont teflon spray and I will try it next time because it's clear so your chain looks clean.
    Lifer ZX-12R's Avatar
    Candia, NH
    Chain lube?
    Quote Originally Posted by 600Gxxer06 View Post
    That is just an urban ledgend. Any chain worth its salt will not be damaged by WD-40.
    I use straight up WD-40 as my only chain lube. It's inexpensive and reduces the parasitic losses in the final drive of the motorcycle.
    Watch all the naysayers come out of the woodwork saying WD-40 doesn't lubricate chains.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Chain lube?
    coincidentally, my buddy with a zx12 uses wd-40 too. It is o-ring safe, but it breaks down quickly... you have to apply every 200 to 250 miles. He kept a small can with him on the bike.
    Quote Originally Posted by Karaya One View Post
    Exactly why I had to get some from you... great stuff.
    Pork and Beans selltekk's Avatar
    Williston VT
    Chain lube?
    WD40 to clean, and Chain Wax to lube.
    I'm going to have to try the kerosene thing for cleaning.
    "Harley Davidson: The most efficient way to turn fuel into noise without the risk of power and handling."
    Selltekk.
    -'04 Yami YZF600R (NOT R6)
    - Uberfast Blue color
    -Two Bros. Exhaust
    -OES Sliders
    -Helibars
    -Mototeck Flushies
    -Factory Pro Shift Kit
    <a href="http://www.linkedin.com/in/davefortin" ><img src="http://www.linkedin.com/img/webpromo/btn_viewmy_160x25.gif" width="160" height="25" border="0" alt="View David Fortin's profile on LinkedIn"></a>
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Chain lube?
    I used to use WD-40 to clean but the biggest problem I had was that even after you wiped the chain dry, WD-40 would get inside the chain and when you went for a ride to heat up the chain, the WD-40 would fling out all over the place expecially on the tire (NOT GOOD).
    I use Chain Clean by Motorex. It works better then WD-40 I think and it completely dries up within 5 mins of you spraying it on the chain.
    http://www.motorex.com/index.cfm/fus...1351-1393-1395
    I use Motorex Chain Strong lube after I'm cleaning. I like it, it has yet to fling off.
    http://www.motorex.com/index.cfm/fus...1351-1393-1397
    Chain lube?
    Just how does chain "lube" lubricate an o-ring chain?
    Oct 2005
    Kingston NH
    Chain lube?
    The o-ring keeps the lube for the pins in place, to lube the pin against the I.D. of the bushing, not the surfaces that the rollers contact, {the sprocket teeth and O.D. of the chain bushing}. How much lube is needed for them, I suppose, can be argued. I don't see how not lubing them can be good. Granted, there might not be a lot of rotational movement there, {lots of pivotal}, but there is still is high pressure metal to metal contact. Lube would indeed serve as some sort of cushion.
    Chain lube?
    I don't feel the film strength of any chain lube is worth mucking with the mess. WD-40 and DID take me >15k mi. w/o a problem.
    Candia, NH
    Chain lube?
    Quote Originally Posted by ChR1s View Post
    I only use WD-40 on my 12R. The chain has over 23k miles on it and it still is well within its safe tolerances with plenty of room left for adjustment.
    I only use WD-40 on my other 3 motorcycles and haven't had any issues either.
    Norwell, MA
    Chain lube?
    I just picked up some of the dupont teflon lube. I'll let you know how I like it.
    Lifer Currently's Avatar
    Ooltewah, TN
    Chain lube?
    +4 for the Motorex 622 strong.
    I asked the question when I was starting out and Dave told me to try this.
    I just changed out my OEM chain and sprocket ... 20k miles.
    It could of gone another 3 to 5k miles but I want to ride this summer,
    not work on the bike so I swapped it out.
    The rear sprocket still looked good, the chain was a little stretched out
    with no tight spots and the front sprocket was starting to look like
    sharkfins.
    Every Saturday morning before riding, I would clean and grease the chain
    and clean the bike with Honda Spray Cleaner and Polish.
    This year, I am reversing the front sprocket at 10k miles to see if I can
    get longer life out of the chain and sprockets. (steel OEM for long life)
    Edit, Yes, I put over 19 thousand miles in a year and two months.
    Lifer zxme's Avatar
    Mar 2007
    Mass
    Chain lube?
    WD-40 works with out a doubt. I have 13k on mine and it looks new and has barely any wear..I dont soak it all i do is spray some on a rag and clean it..Worked so far..
    Lake Champlain, VT
    Chain lube?
    Feb 2006
    Metro West, MA
    Chain lube?
    Hells yea kitt. I use the exact same cleaner and lube. It's the best products I've used as far as chain care.
    Chain lube?
    any word?
    and where did you buy it?
    Ooltewah, TN
    Chain lube?
    any word?
    Lowes stocks it.
    I prefer the moterex 622 strong ... especially when riding in the rain.
    Norwell, MA
    Chain lube?
    where can I buy kerosene to clean my chain?
    Feb 2006
    Metro West, MA
    Chain lube?
    I've been told Home Depot, and Lowes. Everytime I've gone into one they say they don't carry any. So I just use Motorex's Chain clean product.
    Lake Champlain, VT
    Chain lube?
    Quote Originally Posted by BadBoyBilly View Post
    Candia, NH
    Chain lube?
    Some Hafners gas stations carry it. You can get it at almost any home heating oil company too.
  1. Best chain lube?
    By Tekime in forum Bike Maintenance
    Last Post: 09-05-18, 09:23 AM
  2. Chain lube
    Last Post: 11-08-08, 12:16 AM
  3. chain lube
    By roso in forum Bike Maintenance
    Last Post: 05-04-06, 05:06 PM
  4. Chain lube
    By NHBusa in forum General Bike Related
    Last Post: 05-19-04, 10:16 AM
    Last Post: 05-28-03, 09:17 PM
