Page 2 of 2 FirstFirst 1 2
Results 26 to 45 of 45
Changing brake fluid
    Re: Changing brake fluid
    Yea.................... the .1
    Infected Slyder's Avatar
    Concord, NH
    Oil, huh? Like keepin yer brake lines lubed?
    go hugga tree. brakes have oil, the fluid goes in the blinkers.
    I'd also like to invoke the 2am, was mostly asleep, clause. So I get a pass.
    rrrright down by da beach island boyeee's Avatar
    Quincy, MA
    definitely try to get all the old fluid out. even though it's compatible, it will still boil before the 5.1, so you can get minor fade/bubbles from that.
    i use the RBF600 in my car and it's been great on the track. used to use the ATE, didn't notice any problems with that.
    As long as you stay in a compatible system, IE DOT 3, 4, 5.1, ignore the DOT designator when comparing different options. Look at the actual boil temp rating. There are high quality 'DOT 4' labeled fluids that resist boiling better than cheapie 'DOT 5.1' labeled products, etc.
    Oct 2005
    Wrentham MA
    Quote Originally Posted by tropicoz View Post
    I've heard of ziptying the lever, what does that do?
    Nothing good!
    I see folks doing this,overnight. They say the next day the brake lever feels,"less spongy".
    The only reason the lever feels harder is due to the brake system o-rings have swollen
    Graham
    Yea,
    I've never been a fan of this proceedure. I could never see the benifit from it.
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Yea,
    I've never understood it either. compressing the fluid/trapped air over night is better than just letting it sit? how that does that work? to me it actually seems like the wrong thing to do. when you compress the fluid the air now has to move through a denser material to try to rise to the top.
    you're forcing the bubbles to rise up to the master
    Bridgewater, MA
    so forcing the fluid (and anything else in the lines) downward forces stuff upwards. I don't hold a degree in physics but...
    if you leave it alone the air will still try to rise to the top over night. taping the lines will help more in my opinion
    it could be a myth, but it's suggested very often & it's worked for me in the past.
    Apr 2011
    NH
    I can't think of anything bad that would happen but I see no good coming from it either.
    If you hold the lever down you will block off the bleed port trapping whatever is in the system in the system. If we are talking about one or two bubbles, I think you would be better off bumping the lever so the fluid moves back and forth and makes the air bubble come unstuck from the inside of the line/caliper/whatever. Then crack the bleeder at either the master or the caliper to let the air out. Sometimes it will work its way out the reservoir but I would not count on that.
    If the lever is so soft you can pull it to the bar you need to keep flushing it(or look for something else that could be wrong).
    If I can't see the difference in color, I do 1-2 reservoir (about 1/2-1 cup if I had to guess).
    Tim
    LRRS #44
    Superbike Services 44
    Oct 2005
    Wrentham MA
    the theory is...as fluid does not compress with pressure but gas goes...the trapped air bubbles will decrease in size and possibly work their way up easier.
    Constant pressure on the Orings on the pistons in the master cylinder and calipers for an extended period will actually deform them (swell). The next day the lever feels solid,not due to less air bubbles but due to temporry distorted oring seals
    Graham
    AM #152 tropicoz's Avatar
    Apr 2010
    Maine
    brett, talk to me before ordering RBF600
    can I talk to you too?
    Quote Originally Posted by xsiliconkid View Post
    What did the o-ring say to the distorted seal?
    "Go clubbin?"
    What did the brake fluid say to the distorted seal?
    "Go clubbin last night?"
    Apr 2011
    NH
    Gotcha. air get compressed, moves easier. I still think cycling the system would be a better approach. I know you are not promoting the hold lever down method.
    I'm not sure I buy that it would distort the rubber bits, but if you have seen it I'll take you word.
    I'm going to ask around about this one.
    Tim
    LRRS #44
    Concord, NH
    If air bubbles are trapped in the FLUID (hi Oreo ) putting them under pressure might not loosen them and allow them to rise. tapping lines, tapping master / calipers would in that case knock them lose whereas the zippy tied lever didn't.
    I mentioned one bad thing that can happen. Fresh washers, torqued banjos and fluid, not oil, on the banjo about to drip on the fairing. I left a rag under the master / banjo just in case, glad I did. I really didn't notice a difference in lever feel after the zip tie idea, compared to before. Though Jim is right, it is mentioned a lot. And like I said, the radial nissin master on the gixxers is junk IMO. So perhaps that's why I didn't notice a change.
    Well I found a lot of air in the left caliper, so I did like 4 more cup refills. I think it's as good as it'll get for now. I'll have to re-bleed after Friday's practice.
    No, slow down rookie
    Member ecd2004's Avatar
    Apr 2010
    New Hartford/Colebrook, CT
    oh jesus...
  1. Replies: 5
    Last Post: 07-16-14, 07:32 PM
  2. Brake Fluid
    By oVTo in forum Bike Maintenance
    Last Post: 05-26-09, 08:35 AM
  3. Changing Brake fluid?
    By Josephd14 in forum Bike Maintenance
    Last Post: 03-10-07, 08:27 PM
  4. Brake fluid etc.
    Last Post: 11-11-05, 02:58 PM
  5. brake fluid
    By double agent in forum Bike Maintenance
    Last Post: 04-23-05, 03:56 PM
