Results 1 to 25 of 26
Voltage/regulator rectifier??
    Jun 2005
    Question Voltage/regulator rectifier??
    HEy everyone, Does anyone know exacty what the voltage/regulator rectifier does on the F4i? How does it work? THanks
    The rectifier changes the AC current from your bikes stator to DC current. You need DC current to charge the battery. The voltage regulator regulates the power output to a set voltage so you don't fry the battery or electrical system
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    You're more smarterer than you looks!!
    Jul 2005
    norwood ma
    Re: Voltage/regulator rectifier??
    most motorcycles have a magneto type alternator for simplicity, unlike a car alternator that regulated the output by regulating the field strength of the armature. motorcycle RRs regulate the output by shunting the excess back to ground and dissapating the energy as heat... the faster a magneto type alternator spins the higher the output, means the more excess that has to be dissapated as heat.
    this is why RRs in some bike fail rather regularly, they overheat the semiconductors inside becaust they just don't get enuf cooling air flowing across the heat sink
    Jul 2005
    norwood ma
    WOW------you're even morer smarterer than mark!
    Jun 2005
    checkin one
    How could you check one to see whether or not its fried. IS there a simple way without having to plug it onto a bike??
    Giddy up! joberly's Avatar
    Apr 2004
    Raynham, MA
    If you have your shop manual, it will tell you what the current should be accross the terminals in the RR, and you can test with a multimeter.
    Jul 2005
    norwood ma
    ok------you can join the more smarter club too!
    Apr 2004
    Raynham, MA
    Dec 2003
    Ma
    Have it connected to the bike and check the charge at the terminals. It should be around 14-14.1 or so. If it's around 12 then it's probably junk. I think mine junked out. Leaves me with no bike for Daytona. Unless I go steal Chad's tonight.
    Jul 2005
    norwood ma
    ok--just for that you're OUTTA the more smarter club!!!
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    most proably...i concur...my brothers bike just went through this...it was only making 12ish..replaced it and it was over 14
    be sure to check the voltage after the bike is completely warmed up, when my RR went south, it checked out fine cold, once warmed up, it was bad
    Yeah well if I don't look smart, what the fuck do you look like!!!
    Shut up PUSSY
    I just went through all that crap with my KTM Motaaaahd so it's kinda fresh in me mind. A normal bike should test and hold 14.0-14.3 volts.
    My KTM isn't normal and tests 14.9 with no lights on and goes down to and stays at 12.6 with the lights on.
    dont forget to check the diodes
    Jun 2005
    diodes?
    Are the diodes inside the cooling fin portion of the regulator/rectifier??
    If they are, how can you get to them without damageing the unit?
    Jul 2005
    norwood ma
    [I just went through all that crap with my KTM Motaaaahd so it's kinda fresh in me mind. A normal bike should test and hold 14.0-14.3 volts.
    My KTM isn't normal and tests 14.9 with no lights on and goes down to and stays at 12.6 with the lights on. [/B]
    NO FUCKIN"MOTAHHHHHHD IS NORMAL !!!!!!!!!!!!!!!
    Lifer ZX-12R's Avatar
    Candia, NH
    Re: diodes?
    The diodes are the rectifier. They allow current to flow in one direction but block it in the other. When hooked up properly, they block the negative half of the AC waveform coming from your alternator. If you look through your shop manual, they will tell you what part of your wiring harness to unhook in order to get access to them. It will have you check a combination of points with a multimeter to verify that the diodes in the rectifier are not shot.
    What symptoms are you experiencing that leads you to believe your R/R is acting up?
    Jul 2005
    norwood ma
    ok--you can be in the more smarter club tooo---but that's it--it's gettin too fuller!
    Candia, NH
    Noice!
    Jun 2005
    diodes
    I'm not havin any problems, I just wanted to know how to check. I got an extra Regulator/rectifier for an f4i that appears to be in great shape but looks don't mean much with this type of part. I just wanted to know how to test this R/R without puting it on my bike. Is there a way without having to hook it up to the bike?
    Candia, NH
    You will have to figure out the pinout of the R/R and it will be very easy to check the diodes in it. Checking its voltage regulation is more difficult without having it connected to the bike. You would have to supply the R/R with 20V or more and check the output to make sure it is in the range specified in your shop manual. You normally check its regulation with it properly hooked up and the engine running at 4K RPMs.
    Jul 2005
    norwood ma
    Re: diodes
    fuckin' NO dickhead--read the posts!!
    Jun 2005
    ALAS
    ThE BAll BuSTER RETurns!!!!!
  1. Regulator rectifier replacement
    By Dip Dungles in forum Bike Maintenance
    Last Post: 09-13-12, 09:13 PM
  2. WTB: voltage regulator 95 monster m900
    By SCRLT01 in forum Wanted
    Last Post: 06-22-12, 11:52 AM
  3. MOSFET type voltage regulator
    Last Post: 07-16-10, 05:40 PM
  4. sv650 voltage regulator
    By PPS26 in forum Wanted
    Last Post: 05-06-10, 06:01 PM
  5. voltage regulator test?
    Last Post: 06-05-09, 06:28 AM
