Results 1 to 17 of 17
dual carb ques?
    Just Registered wingerdor's Avatar
    Feb 2008
    Upstate NY
    dual carb ques?
    I bought a 250 ninja for my training site and it idles up with the choke off, but idles down and stalls out with the choke on. The bike did sit for a while. I ran the carbs out of gas before I took them out. After taking them out, the one is dirty and when I flipped it over it dumped gas out (just the dirty carb) I have sprayed the hell out of both sides with cleaner and gotten some gunk out of the one that had gas still in it. Anything specific I should check before I put it back together. I have only ever messed minimally with single carbs.
    I hate the idea of putting it back together and having the same problems.
    Thanks!
    I love FI'd bikes!
    Ask me about Total Control ARC Level 1 and Level 2
    in Troy, NY and Loudon, NH
    John
    http://www.youtube.com/watch?v=fSVg3Gg4LmA
    '02 GL1800A Silver (Track Toy)
    '12 Striple R
    "I hope I always have a little more skill than stupidity"...Lee Parks
    Re: dual carb ques?
    You didn't say it, but I assume you pulled the jets out & let them soak in carb cleaner?
    Check the needle valves as well. Doesn't take much to make em stick.
    Andover
    Re: dual carb ques?
    If you have it apart yake the jets and soak them. Then blow air throught them, you can get a nozzel with a rubber tip. Better yet just order new ones since you have them apart, they cost about 3.50 each. Next year drain the carbs instead of letting the gas burn out, that still leaves gas in the bowls.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: dual carb ques?
    Don't just trust compressed air to clean your jets. I run a wire through each one. Then spray carb cleaner to assure I can see the are open. The same with the choke circuit.
    Posted by Jane in BoxChat
    Andover
    Re: dual carb ques?
    Yep, you could also get jet cleaning wire. Hold them up to the light and look through when you are done, make sure all the holes are clear.
    Sep 2006
    Around the corner
    Re: dual carb ques?
    I had the same problem with my wifey's bike 2001 ninja 250. yeah the jets the jets the jets ......... on the side of the carb is a white plastic circle with two screws holding it. under that cover is a diaphragm with a spring return so be ready to catch it.
    there are two things to do here with carb clean and compressed air.
    1. the cover has a small pollup with an air passage towards the diaphragm that needs to be cleaned and blown
    2. the diaphragm holds a metal penis type thingy that needs to be cleaned and blown also
    3. take the bowl off and clean the jets
    4. satating the obvious here but you did change out the gas in the tank ... right?
    5. you don't have to separate the carbs to do this op.
    The rule is:
    Jul 2008
    Waitsfield, Vermont
    Re: dual carb ques?
    Haven't cleaned 'em yet, but I'd check out Cleaning the carbs 1 - Ninja250Wiki and Cleaning the carbs 2 - Ninja250Wiki for detailed instructions.
    Northshore/Beverly, MA
    Re: dual carb ques?
    +1
    just carb cleaner, and a blast of air, will not break up the crap that solidifies in the jets.
    serial lurker gs500fast's Avatar
    Sep 2007
    Belmont, Ma
    Re: dual carb ques?
    did you say ninja 250?
    Is there a carb sync tool? - Ninja250Wiki
    I never synced my carbs after taking them apart and the bike runs fine. still, something you might want to do thats specific to dual carbs
    Re: dual carb ques?
    Quote Originally Posted by gs500fast View Post
    Not doing that is like taking a dump, and not wiping yer ass with any multi cylinder engine. I've never found any to be spot on, and this is even from the factory. This is why my tunes ROCK!....
    Westford, Ma
    Re: dual carb ques?
    Not doing that is like taking a dump, and not wiping yer ass with any multi cyclider engine. I've never found any to be spot on, and this is even from the factory. This is why my tunes ROCK!....
    +1 I always synch multi carbs..
    Sep 2007
    Belmont, Ma
    Re: dual carb ques?
    good to know. I didn't think it was essential to the process but I was good and newb when I did the carb rebuild. guess I know what I'll be doing this weekend.
    cool.
    Lifer greenmonster's Avatar
    Aug 2003
    Re: dual carb ques?
    True that!
    Feb 2008
    Upstate NY
    Re: dual carb ques?
    Wow, Thanks for all the great info. Will re-tackle them tonight.
    John
    '12 Striple R
    Feb 2008
    Upstate NY
    Re: dual carb ques?
    Well, I cleaned it all out with cleaner, soak, wire, air pressure. spottless. drained the tank out and sloshed it around to get any crap out. put it together, put gas in it started it, warmed it up tweeked the idle. (Couldn't sync the carbs yet. no tool, shop to busy) Took it for a spin and it was running fine. wound it up in 1st gear and just before it redlined it stalled and won't restart! ARGH!! I let it sit and still nothing.
    Help...
    John
    '12 Striple R
    Re: dual carb ques?
    Sounds like fuel starvation or something... ya hook up the fuel lines the right way? Petcock on & all that jazz?
    Feb 2008
    Upstate NY
    Re: dual carb ques?
    When ever it starts to die, if I take the vacuum line off the fuel valve it revs right up so it's air hungry. I took the petcock diaphragm out and it doesn't look great. Is there another way to adjust air. Could I have f'd up the vaccum pistons?
    John
    '12 Striple R
  1. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
  2. Carb help please.
    By Doc in forum Bike Maintenance
    Last Post: 05-08-07, 11:50 AM
  3. front end ques.
    By double agent in forum Bike Maintenance
    Last Post: 07-26-06, 04:48 PM
  4. More tire Ques.
    By PinHead in forum General Bike Related
    Last Post: 04-09-02, 08:46 PM
  5. Clutch bleeding ques.
    By PinHead in forum Bike Maintenance
    Last Post: 08-31-01, 08:13 PM
