Results 1 to 7 of 7
Engine Internal Swap Advice
    Jan 2009
    Waltham
    Wirelessly posted (Infuse)
    Me and my father will be taking off the top end of my 98 superhawk as well as cracking the crankcase open aswell. The goal is to swap everything inside of one crank into a shinier, less broken one.
    I am looking for simple do and don'ts from people who had to learn the hard way or people that found a trick or two. I have a service manual and will be working with that. Nothing is stupid, especially if anyone has "while your in there advice".
    Let the shit show begin,
    Chris
    Lifer union's Avatar
    Blackstone, MA
    Re: Engine Internal Swap Advice
    Replace the bearings while youre in there
    James
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    take a fastener off, immediately put it back where it is supposed to go. don't do the bag thing.
    -Benjamin Franklin
    Massachusetts' Noth Shoah
    I did use bags, lots of them, as well as putting nuts back on their bolts when it was the right thing to do. Labeled the Ziploc bags with a sharpie and kept them in order.
    1. Get a notebook. Write down what you do in order. Don't skimp on the descriptions.
    2. I swapped a motor, so this may not apply to you, but I labeled every electrical connector and its mate with duct tape.
    3. Take pictures. Lots of pictures. You won't need most, but the one you need will be priceless.
    I bet it'll come out great
    Go fast. Have fun. Repeat.
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Plus on on the electrical connections. Label both sides of each one (1,2,3) and so one do when you put it back together 1 goes with 1....
    Equal Opportunity Asshole DroFiveOh's Avatar
    Apr 2012
    While you're in there:
    Don't fuck it up.
    49 states do it one way, and Massachusetts does it their own way.
    Jan 2009
    Waltham
    Good advice on the bearings I will check this out. I am pretty sure we will be removing bagging because my dad is compulsive when it comes to that crap. As far as the connectors go.... it's a 98 superhawk. I had to remove a total of 5 wires from the engine. All of which I am fully acquainted with due to my electrical issues of the past fortunately/unfortunately.
    Keep up the good advice!
  1. Grom Engine Swap
    By MaRce1o in forum General Bike Related
    Last Post: 12-07-15, 11:02 PM
  2. Finished: Triumph Street Triple 955i into Sprint RS engine swap!
    By KingCast 650R in forum General Bike Related
    Last Post: 03-19-11, 11:35 AM
  3. Internal Engine Videos
    By obsolete in forum General Bike Related
    Last Post: 08-10-10, 09:28 AM
