Results 1 to 3 of 3
ex250 carb cleaning: this afternoon/evening?
    Senior Member dhawks's Avatar
    Apr 2008
    Just removed the carbs from my fiancee's ex250, but I am unsure of how to proceed: what to remove, what to clean, what adjustments to make (if any), etc.
    Anyone available to walk me through this? Would be much obliged. I'm in Roslindale, but can bring carbs, Oktoberfest, and some homemade salsa.
    PM me, and I'll shoot you my number.
    Thanks.
    /s/ Dustin
    LRRS #767
    '09 R6 / '11 848 Evo / '99 RS250
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: ex250 carb cleaning: this afternoon/evening?
    Flip them upside down and start by removing the fuel bowls. Drain and clean. Then carefully remove the float and needle. You will see two jets, a main jet and a low speed jet. It's most likely the low speed that is causing you issues. Clean it with a wire. A twist tie from a loaf of bread works good. Reassemble, reinstall and try in. DO NOT adjust any screws on the sides of the carb. Best to do one carb at a time if you are unsure of what you are doing.. for referrence. BIKEBANDIT.COM has exploded views of your carbs
    Posted by Jane in BoxChat
    Jul 2008
    Waitsfield, Vermont
    http://faq.ninja250.org/wiki/How_do_...n_the_carbs%3F
    Having the right screwdrivers is a very good idea, as is having allen-head bolts (4mm x 0.75 x 16, I believe, but it's in the FAQ; what's not in there is that you need 8 of them) to replace the tiny, easy-to-strip float bowl screws.
  1. July 1 late afternoon evening, Central MA? RI?
    By The Snowman in forum Rides & Events
    Last Post: 07-01-11, 08:44 PM
  2. Shop for carb cleaning?
    Last Post: 12-27-09, 07:56 AM
  3. Riding this afternoon/evening...
    By DocCola in forum Rides & Events
    Last Post: 08-25-09, 01:26 PM
  4. Mototown 3/11 or 3/12? Afternoon or evening?
    By JRide in forum Dirty Bastards
    Last Post: 03-08-09, 07:00 PM
  5. carb cleaning
    Last Post: 06-19-08, 03:28 PM
