Results 1 to 21 of 21
Tube pressure
    Lifer Pittenger5's Avatar
    Austin
    Tube pressure
    Since we're talking tire pressures for something I Have no clue with, how do you know what pressure to run when youre using tubes with a tubeless tire? For example, in the case of the motarded folk amongst us.
    Zip Tie Alley #505
    san fran
    Re: Tube pressure
    depends on the tire maker
    Austin
    Re: Tube pressure
    I would think the tire wouldnt have much to do with it, more the tube manufacturer.
    Zip Tie Alley #505
    san fran
    Re: Tube pressure
    pretty sure there is a psi recommendation on the tire itself. i only have used tubes in my dirtbikes never a sumo so not sure how it works with a road tire, but the tube should have no problem handling the 30 some odd psi.
    Re: Tube pressure
    Quote Originally Posted by catch2otwo View Post
    I run my Motard @ like 22-24
    and My dirtbikes at 12-11
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Dec 2003
    Ma
    Re: Tube pressure
    PSI = PSI whether it's in a tube or a tubeless tire.
    Re: Tube pressure
    What PSI do you run?
    Dec 2003
    Ma
    Re: Tube pressure
    Quote Originally Posted by BLACK SQUIRREL View Post
    All of them!
    Dec 2003
    Ma
    Re: Tube pressure
    Was that a serious question?
    It depends on the tire, the track and the weather.
    Austin
    Re: Tube pressure
    But wouldnt the tube have a different PSI than the tire? It's 2 seperate "layers" and profiles, so wouldnt the PSI of each be exclusive?
    Zip Tie Alley #505
    Meriden, Ct
    Re: Tube pressure
    No...
    Dec 2003
    Ma
    Re: Tube pressure
    Does the pressure push on the tire any more or less with a tube in between?
    Austin
    Re: Tube pressure
    No...
    Ok, sounds good
    Zip Tie Alley #505
    Austin
    Re: Tube pressure
    I dont know how tubes work, does it fill in every available space air does, or are there gaps in places.
    Zip Tie Alley #505
    Dec 2003
    Ma
    Re: Tube pressure
    here's how it works: tubeless tires have invisible tubes in them.
    Austin
    Re: Tube pressure
    Correct ... except dont most motards use tubes WITH tubeless tires?
    Zip Tie Alley #505
    Re: Tube pressure
    The pressures are not based on the tube or the tire it is based in the power and weight of the machine and rider and how the tire reacts to that stuff (ie grip sidewall flex ect
    Meriden, Ct
    Re: Tube pressure
    A tube fills all the available space between the rim and tire. Even if it didn't, any space in between isn't pressurized, so it wouldn't matter. When you inflate the tube, it pushes any ambient air out of the tire and fills that space with pressureized tube.
    Bu to answer your original question. You only need worry about the pressure at the valve stem.
    Oct 2005
    Wrentham MA
    Re: Tube pressure
    need tube if using spoked rim....as the rim is not air tight... unless it's a funky bmw with the spokes going to the outside of the rim....
    Graham
    Austin
    Re: Tube pressure
    Gotcha. Makes sense.
    (whats up with the parts)
    Zip Tie Alley #505
    Re: Tube pressure
    My reading suggests that the tube's impact in tire pressure recommendations is based more on the tube adding thermal mass, therefore making the tire slower warming compared to the same setup run tubeless. So you tend to lower the pressures slightly to counter the extra thermal mass (and to a tiny extent, extra stiffness from the extra layer of rubber)?
  1. Wanted - Parts & Tools | WTB 01-03 GSXR Ram air tube
    By Shock3r in forum Wanted
    Last Post: 01-15-14, 08:34 AM
  2. Tube is a tube is a tube?
    Last Post: 11-08-13, 07:40 AM
  3. Replies: 2
    Last Post: 09-10-12, 03:00 AM
  4. you tube and wap
    By SVRACER01 in forum Site Info & Suggestions
    Last Post: 01-28-11, 01:31 PM
