Results 1 to 25 of 32
F4i Maintenance
    F4i Maintenance
    Going to change the coolant in my bike as its about 10 years old....only 12k miles on it but I think its time to change it.
    How many quarts do I need? I thought i had read 4 somewhere, but some other posts on forums say only 3.... I trust you Nesr'ins so help me out.
    '02 F4i
    still a newbie j4eric's Avatar
    Aug 2009
    Grafton, MA
    Re: F4i Maintenance
    I just fill it up after draining.....then burp it...then fill it up again while burping.
    08 CBR 1000RR street bike
    99 R6 track bike
    02 F4i sold to a nesr member
    Changed the coolant today.... Only took 2 quarts tho. Manual said it should take close to 3. I followed the instructions in the manual... How the hell did I miss a quart in there?
    I took out the drain plug and drained the overflow hose....
    '02 F4i
    Lancaster
    Wirelessly posted
    Pretty sure my 600rr only takes 2 usually. Did you drain the engine block and the water pump drain?
    Corey
    Yup. Didn't flush it with water though. Only drained the hose and bolts.....
    '02 F4i
    Re: F4i Maintenance
    F4i Maintenance-photo-1-1-jpg
    Pic above is right side of bike. Notice the empty screw hole.
    WTF goes here?
    There is a bolt on the other side that is in the same position.
    '02 F4i
    Re: F4i Maintenance
    Heres another pic of the screw hole
    F4i Maintenance-22222-jpg
    '02 F4i
    Wirelessly posted
    Radiator mount bracket?
    who knows
    Re: F4i Maintenance
    could it be a blank hole used in manufacturing and left there
    or
    they use the engine block in another bike and on yours it's not used (F4i and 600RR are the same engine with a few modifications ?)
    or
    maybe an option you don't have. do they make engine block heater for bikes? I thought I saw one for my bike before
    If your bike isn't missing anything I would worry about it.
    The hole is threaded... That's why I am puzzled.
    '02 F4i
    Just switched out the oem air filter for a k&n.
    Any idea why the oem has 2 pieces of plastic that sort of flare up, while the k&n doesn't?
    '02 F4i
    KB KB's Avatar
    Manchester NH
    Re: F4i Maintenance
    Quote Originally Posted by Kazinator View Post
    I am not even going to read this whole shitshow.
    You know how many quarts you need ZERO. It's a fuckin honda who gives a fuck that the coolant is 10yrs old. Just run the thing already.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    That's old news. Already changed it.
    '02 F4i
    Bump
    '02 F4i
    Aug 2009
    Grafton, MA
    Re: F4i Maintenance
    Pic would help
    99 R6 track bike
    Re: F4i Maintenance
    Because the K&N is aftermarket.
    Asking that is along the lines of asking why a slip-on exhaust is louder than stock.
    Still a legitimate question tho...
    Wondering what the purpose of those flares on the oem are as they are pretty large.
    '02 F4i
    Aug 2009
    Grafton, MA
    Re: F4i Maintenance
    i will answer without seeing what you are talking about.....i think they are for keeping the air filter in place.
    aftermarkets do not have these as they know better.
    Honda engineering sometimes goes overboard.....you will know what i am talking about if you DIY Honda's...perfect
    example is the brake rotors on Honda cars, they have a screw that bolts on to the hub.....the rest of the world dont do this
    hence any aftermarket you get for honda rotors will not have the hole for the bolt.
    99 R6 track bike
    Re: F4i Maintenance
    F4i Maintenance-08-jpg
    (not my picture)
    Notice the 2 wing/flap things on the front of the oem air filter. The k&n lacks this.
    '02 F4i
    Aug 2009
    Grafton, MA
    Re: F4i Maintenance
    i stand by my statement then.....it is there to keep it in place.....but that is the Honda way.....over the top
    99 R6 track bike
    Re: F4i Maintenance
    I was wondering if it aided in the direction/flow of the air within the box.....?
    '02 F4i
    Re: F4i Maintenance
    Ride more. Worry less.
    I'm going to guess that those are there to reduce the amount of intake noise because I know when I'm using all the power on mine it's effin' loud underneath that fuel tank.
    FWIW; the BMC in my F4i doesn't have those either.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Re: F4i Maintenance
    Those big friggin fins? They look very much like air directors. Like bergs said probably acoustic. Never owned an f4i but worked on Honda's cars with friends. They do all kinds of weird shite when it comes to intake piping etc. Just ride the thing if you notice something adverse after changing the filter deal with it then. If not don't worry about it.
    Re: F4i Maintenance
    Definitely not worrying about it, just curiosity.
    I have ridden about 150 miles with the k&n air filter and havent noticed anything really different yet. Acoustic-wise I actually thought it has sounded a little bit quieter with the k&n.
    '02 F4i
    Re: F4i Maintenance
    Yer gonna loose like 50HP! Best make it up with stickers or by extending your swing arm.
  1. pre-season maintenance
    By kermita in forum Bike Maintenance
    Last Post: 03-19-07, 09:22 PM
  2. Need help with maintenance..
    By Ecooke21 in forum Bike Maintenance
    Last Post: 03-03-07, 02:37 AM
  3. Routine Maintenance
    By Boner in forum Bike Maintenance
    Last Post: 07-10-06, 09:22 PM
  4. What maintenance have you done?
    Last Post: 02-20-05, 07:12 AM
