Results 1 to 19 of 19
Fuel Injected SRAD Keeps Dying
    Feb 2012
    I've got this 98 SRAD 750 (first year of FI) that I just can't get to stay running.
    When the issue first happened I bumped the idle up a little bit and put 5 miles on it around town. Seemed ok.
    When I got home, as soon as I put it on the kickstand the idle started falling slowly. It got under 1000 then hit 5-600 before I shut it off.
    Is this a sign of a failing fuel pump? What else should I look at? I set the throttle position sensor using the dealer mode per the manual.
    I'm about to bring it to the shop with carte blanche
    Too many bikes to list
    Mosdt likely drunkd
    Re: Fuel Injected SRAD Keeps Dying
    Pinched fuel line or blocked fuel cap vent will do that. See if it happens with the fuel cap open and the tank propped up a little. If it still does it, I'd check the screen in the fuel tank attached to the pump.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Feb 2012
    I'll give it a shot when I get home. If the vent is blocked, is not allowing the fuel to actually flow?
    Mosdt likely drunkd
    Lifer Falko's Avatar
    MoonTown
    Could be crapped out fuel lines. Late 90's fuel line was very susceptible to ethanol damage in boats, might be the same for bikes.
    Yes. If the cap vent is blocked, it will cause a vacuum and fight the pump. When this happens, if you open the cap, you get the whooshing sound of air rushing into the tank.
    Tell it to grab it’s bootstraps.
    Feb 2012
    I should just tell it to make itself great again. Best looking bike from the 90s.
    Sent from my Pixel XL using Tapatalk
    Mosdt likely drunkd
    Exactly. Except for the good looking part.
    The hottest bike from the 90’s is the 996, imo.
    Feb 2012
    Woah woah. You're just wrong.
    For example the 1993 ZX7.
    AND the SRAD
    Mosdt likely drunkd
    ZX-7RR. Just hot.
    Hottest bike of the 90's...
    Feb 2012
    Too late!
    Mosdt likely drunkd
    Too late!
    I believe the R7 was a 1999 model.
    Too late!
    Production was in 99...
    Yamaha YZF-R7 - Wikipedia
    Member motoarch's Avatar
    Dec 2011
    Norwalk/ new london
    And it’s not even close fools. Better check yo self before you wreck yo self
    R7 gets an honorable mention, but in my world, a motorcycle should never have more than two cylinders.
    Quote Originally Posted by motoarch View Post
    Mic drop from motoarch
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    Ya that MV wins it for sure.
    Any luck with the running issue?
    Shit. I had no idea those bikes were that early. Gorgeous.
  1. KTM fuel injected 2-strokes due in May
    Last Post: 11-15-20, 02:56 AM
  2. Replies: 2
    Last Post: 05-03-19, 02:56 PM
  3. PTwins dying
    By Kurlon in forum Pit Area
    Last Post: 05-10-13, 07:10 AM
  4. dying leathers
    By bigred875 in forum General Bike Related
    Last Post: 05-05-06, 11:11 PM
