Results 1 to 4 of 4
GSX-R750 Electrical issues (2006)
    Jul 2006
    Hollis, NH
    Some of you might already know that I'm having electrical issues with my gixxer. It draws 1 Amp with the ignition turned off. The service manual says leakage current should be about 3 mA. I have been able to get the current "short?" to go away by unplugging the instrument cluster connector but that connector probably goes to the ECU and a bunch of other places on the bike. Toughest part is everything is working. If it was a wiring harness short, I'd think somewhere something wouldn't be getting proper voltage and therefore would not function but that isn't the case. Everything works fine if i charge the battery. It's not the charging system either since I checked the generator, rectifier and regulator yesterday before I realized there was too much leakage current.
    The only electrical I've added is the Battery Tender connector in 2006. Nothing new since then.
    Anybody have a clue what this might be?
    Re: GSX-R750 Electrical issues (2006)
    Gixxers are notorious for rectifire issues...ride it a bit and see if its real HOT, may have a short inside. Also there may be a load on the stator and its poss also shorting out...lot of the people who run LED, glove warmers Ect tend to put more strees on the coil then its really made for so it shorts and causes all kinds of weird symtoms.....or have you also tried swaping out batteries...as just a Dummy try....cause anything is poss with electric.
    I have an extra gsxr battey if you want to use it....or need any help
    <---- R.I.P. Hauptman's Avatar
    Pepperell, MA
    I'll admit that I don't know much about electrical issues but I popped 2 battery tenders and my bike was having charging issues too. It turned out to be a bad battery tender connector that was shorting. When I tested the leads on the connector it was drawing about 1 Amp too. All I had to do was switch the connector and no more problemo.
    Jul 2006
    Hollis, NH
    Yup, swapped out the battery already. It worked while it was charged but with a 1 Amp draw overnight with the ignition off, it doesn't last.
  1. For Sale - Motorcycles | 2006 Suzuki GSX-R750
    By Cheese in forum For Sale
    Last Post: 10-13-15, 09:53 PM
  2. Replies: 1
    Last Post: 04-23-13, 04:48 PM
  3. GSX-R750 Electrical Issues?
    By QuincyGixxer in forum Bike Maintenance
    Last Post: 07-16-12, 08:15 PM
  4. FOR SALE 2006 GSX-R750 2500 MILES
    Last Post: 05-09-08, 06:58 PM
  5. 2006 GSX-R750
    By 2002silverex in forum General Bike Related
    Last Post: 02-22-06, 05:23 PM
