Results 1 to 12 of 12
removing throttle?
    Lifer akira700's Avatar
    Apr 2005
    in the city
    removing throttle?
    So anyone here know how I can remove the throttle easily?
    the housing on the right side that has the starter switch has
    the throttle cables pass through it. I cant figure out how to
    get the cables off the throttle tube without really ripping at them.
    Doesnt seem to be enough slack to get the thing rotated enough to
    slip em out the slots.
    help!
    2008 Honda CBR 600RR
    Re: removing throttle?
    There is an adjuster nut near the handlebar on one of the cables. Loosen that and see if it gives you enough room to pull the assy....if not, the next step is to roll the throttle "on" and grab ahold of the rear cable at the same time. This method can be tricky with certain bikes...not sure if your's is one of them.
    First thing is to loosen that adjuster near the bars.
    Apr 2005
    in the city
    thanks man for the help... I just stood there long enough till I had that
    miracle moment... I loosened all the adjusters till there was some slack, then got a zip tie under the cable and used that pull and guide the cable out through the release slot in the throttle tube. Man zip ties rule! Previously I was pulling with needle nose pliers and that was not nice to the cable.
    So got the housing off. Soldered one loose wire connected to my starter switch and voila! Lights on my bike again !
    Wrenching rocks when it works huh! Its the pits when it don't but when it all comes together its really good feeling!
    i'll let you know soon, when i put an R1 throttle on my bike soon
    Nov 2007
    Why soon are you soon replying to this soon thread with an soon answer when it soon has already soon had its soon question soon answered soon and issue resolved soon?
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Quote Originally Posted by akira700 View Post
    Man zip ties rule!
    <checks signature>
    You say this as if I don't know that already...
    Quote Originally Posted by ceo012384 View Post
    soon, someone will put you in your place
    And why would you desecrate the Yamaha parts bin like that?
    Remove grip and insert R1....
    So you get a 1/4 turn throttle
    Apr 2005
    in the city
    No shoulda after all the work. I had a loose wire on the starter switch which
    was causing my lights to not work. Took me a bit of work to figure this out though. Tore the front upper cowling off to change the relay, then took apart the high/low beam switch... then finally thought to try the starter switch.
    actually it's a 1/5 turn. stock gixxers are 1/4 turn.
    Sorry Gixxer GOD.....LOLOLOL
  1. Removing top end carbon buildup
    By Tekime in forum Bike Maintenance
    Last Post: 07-07-16, 04:24 PM
  2. Removing Chain Grease?
    By SquadraCorse in forum Bike Maintenance
    Last Post: 06-11-13, 06:28 AM
  3. removing lowering link
    By burtonboarder23 in forum Bike Maintenance
    Last Post: 06-23-10, 08:16 AM
  4. removing rust from a gas tank.
    By taxonomy in forum Bike Maintenance
    Last Post: 08-20-08, 06:55 PM
