Results 1 to 7 of 7
help with motor mount
    Ma
    I dont post here much, but need some help.
    I changed out the spark plugs on my 10R yesterday, and to make matters worse, one of the upper motor mount bolts cross threaded. I backed it out and ordered a few new ones.
    The bolt goes into the frame just above the head. I cant re-thread it as I only have 2 inches to work with.
    Any ideas would be helpful.
    I like cats.......but I can't eat a whole one by myself.
    Re: help with motor mount
    can you put in one of those new thread kits? check ceo012384's R6 rebuild thread.
    Helicoil (sp) or just Tap it to a bigger thread size and locktight it.....no bigggie
    Also try and run a tap in the hole and see if you can clean up the threads a bit may be a pice of thread still in there ..
    Ma
    thanks guys... I found a tap kit, will try from inside the frame to retap...
    Why Kawi built the mounts like this is beyond me...I managed to scrape half the skin from my hand so far...going back for the rest of it tonight.
    shawn nailed it. i couldnt remember that name (helicoil). chris said it wasnt hard when he did it on his R6. i'd suggest you talk to him for installation tips/questions, but he may start sending you pictures of himself in a g-string. just dont say i didnt warn you.
    Quote Originally Posted by noudidnt View Post
    Yea, just go in slow and straight and use a Bit of LUBE...and next time buy Suzuki they don't Break........ever
    Ma
    nice!...thanks...will take it under advisement
    I will hold off on Pm'ing anyone...there are some things in life I dont need to see
  1. Ninja 250 motor transplant... what motor to use?
    By DynoTune in forum General Bike Related
    Last Post: 01-06-14, 08:04 AM
  2. How To : Steering Stem Droid Mount/ Ball Mount for GPS
    By importcustomx in forum General Bike Related
    Last Post: 07-02-12, 10:37 PM
  3. DIY GPS mount
    By idratherberidin in forum General Bike Related
    Last Post: 07-24-09, 11:09 PM
  4. Is this a high mount or a low mount pipe?
    Last Post: 12-27-02, 11:09 PM
