Results 1 to 23 of 23
Hyper-Pro issue
    Jun 2005
    Hyper-Pro issue
    does anyone here have an RSC Hyper-Pro stearing dampener? Heres the problem, Iwas pulling in to a gas station the other day and All of the sudden my stearing got really tight. I stopped and checked the adjuster on my Dampener and loosened it. This has never happened before. It seemed like the adjuster knob wasn't doing a whole lot and the Hyper pro randomly got tight and loose unless I turned the knob basically to the off setting. The adjuster is supposed to set the dampening sensitivity but the dampener seemed to be acting randomly. Has anyone with a HyperPro ever had this happen? could it be because of the amount of rain and temperature drop lately?? Thanks
    Hyper-Pro issue
    maybe the rain dampened your dampener...
    It's "DAMPER"!!!!
    Hyper-Pro issue
    id hate to say it but hyper pro is made by Micron............... good luck
    Jun 2005
    Hyper-Pro
    Problem possibly solved. It might be a viscosity issue. I talked to Hyperpro and the guy was really cool about the whole thing and said if it isn't a viscosity issue, to send it in and they will test & take care of it. SInce we just had a major drop in Temp. in Boston, The dampener is reacting tighter because of the thickness of the oil. When I turn it off, its basically ok. Solution: can't ride like a jackass in the cold weather. Also, take a heating pad, wrap it around the dampener, and then see how it reacts. If its back to normal, then its a viscosity issue, if it doesn't change then its time to send it back to Hyper-Pro.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Hyper-Pro issue
    DAMPER!!!!!!
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    Hyper-Pro issue
    HEY FIREFAG!
    1st off---another useless thread!!!
    2nd----as everyone has tried to tell you--it's DAMPER!!! NOT DAMPENER!!! JACKASS!!!!!!
    Jun 2005
    Hardcore
    THanks for settin it straight (Damper) wicKeD sMaaaaaaaaahttt
    I only post useless threads in my attempt to some day rival the Post whore, Oreo.
    Hyper-Pro issue
    better get movin, i'm puttin in close to 10 posts a day
    Jun 2005
    ahahhah
    Some day Pete........Some day I shall rival the thrown.......
    Are you home?
    Hyper-Pro issue
    nah dude, just got to work.... workin till 11 like usual
    Wanna go ridin tomorrow? swing by, honk & wake me up... no earlier than 10am though
    Jun 2005
    Hell Yeah... THe only problem is ...its supposed to rain tommorrow.
    ITs shitty enough out with the cold weather. Yo I ordered the 2004 moto gp review and the Fastest bikes on the planet. Hopefully one will finally arrive today
    Re: >>>>>>>
    *checks www.weather.com ...........
    RAIN / SNOW?!?!?!
    Aight... Sunday it is
    Jun 2005
    QuoteFamily Guy)"YOu know what Grinds my Gears....FuuuuuuuOOOOOOOOCK yooooooooooouuuuu" SOn of a bitch!! Weather man is a dooshbag because he fucks with my well being...Bastiiiiiddd!! We'll see what happens???
    Jun 2005
    UPDAte
    The damper is cooked. Sent it back to annitori distributing today. There gonna test it and either fix the problem or send me a new one I hope.
    Jun 2005
    Hyper pro
    These son's of bitches!! They'Re trying to tell me they can't do to anything to help me out because the damper was damaged. This is complete BullShit. There were a couple of scrapes on the paint from the bracket. Anyone know of a higher up I can talk to about getting this thing replaced free of charge?? I've only had the stinker for 5 months..
    Hyper-Pro issue
    I run the RSC damper on my bike at its lowest setting for most riding. For choppy stuff, +2 clicks. No issues with it so far, and it was unobtrusive this past Saturday.
    Jun 2005
    damper
    HEy man, does your damper tighten up a shitload after setting it 2 or 3 clicks? I have the same one you do , color and all. The difference is, The mounting bracket mine uses it different from the one I've seen. Everytime I've seen one it has had the same mount set up as yours with the stem bolt. Mine mounts in place of the two gas tank screws just behind the triples and the piston connects to a bracket attached to my fork. Have you seen this set up before?? Thanks
    Hyper-Pro issue
    I've only run the damper @ +3 clicks on the gnarliest of VT pock-marked pavement. I know that just one click makes a dramatic difference in "feel."
    Cold temps will certainly effect the dynamics of the damping oil, and shrink the seals some, just like it does to the other dampers (forks & shock) on a bike. I don't ride the sportbike in frigid temps though, so I can't really relate that much.
    I've seen the damper mounting setup you describe, but with other dampers. Regardless, the stroke of the piston in relation to the bars is not linear. And you shouldn't want to have the damper "on" so much that you can feel it just by moving the bike around at a stand still. While riding, I can percieve just one click from full "off," yet the damper's action is almost unnoticeable while maneuvering the bike.
    Jun 2005
    cool
    Thanks for the insight bro. I'm hoping that Hyper-pro will stand by their product and not screw me. I'm still waiting for a call back from either the dealership that installed it or annitori distributing. They are in debate about what to do with my situation. Supposedly, Annitori Distributing emailed photos of the "damage"(COmplete B.S. Only cosmetic scrapes from mounting bracket) To the dealership because Annitori is claiming that the installation of the damper is the reason it failed. This is shady...why would it work fine for 5 months without inncident and then suddenly fail...PLUs, according to the Hyper-pro website, the twin tube design of the damper is suppose to prevent any interference that the bracket might cause to the piston inside the damper.. I hope this story has a happy ending..
    Jun 2005
    solved
    After a little bit of communicating back and forth, Annitori Distributing helped me out. They new about the bone heads at the dealership I was gonna have to deal with so, They hooked me up with a goodWill warrenty and They are sending a new one in the mail>> YEAHH. I love the damper, Hope this one holds up , Knock on Wood.
    Re: Hyper pro
    TOLD YA SO!
    Re: solved
    Oh yeah, Oxx.... ya sure told HIM
    Jun 2005
    haha
    Either way, Im just glad they helped me out. The big debate i think was over who was gonna take the hit for the replacement, Annitori or the dealership that installed it. In the end, Annitori saved me the hassle of dealing with the dick-bag service manager at the honda dealer that installed the damper. Instead of having me go through the BS with the dealership, Annitori said, " you've been really cool about this and I understand what its like to deal with a bunch of bone heads so I tell you what, I'm gonna get the company to issue a goodwill warrunty and send you a new damper immediatly". FLIPPIN SWeeeeet!!!!
  1. Hyper 796 for commuting into cambridge?
    By black in forum General Bike Related
    Last Post: 09-19-22, 02:43 PM
  2. hyper 821 suspension
    By feralchimp in forum General Bike Related
    Last Post: 11-09-17, 04:44 PM
  3. Trade the 998 for a Hyper?
    Last Post: 06-21-10, 09:15 AM
  4. How much should I offer for this hyper?
    By LowSider in forum General Bike Related
    Last Post: 06-08-10, 05:58 PM
  5. Hyper Truck...
    Last Post: 07-11-09, 01:04 PM
