Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 53
Kurlon
    Lifer Pittenger5's Avatar
    Austin
    Kurlon
    Is there any reason one of my secondary fuel injectors would be unplugged? I have a Bazaaz on there, and I can't remember if I unplugged it when I was pulling a radiator, or if its not needed.
    I don't see a plug it could go into, and its the only thing I can find unplugged.
    Zip Tie Alley #505
    Re: Kurlon
    I can't imagine why you'd leave it unplugged.
    Austin
    Re: Kurlon
    Me either, but Im 98% sure its been unplugged. I don't think I unplugged it, and I can't see where it would plug in.
    Only reason I think thats what it is is from the wire colors and the service manual.
    Zip Tie Alley #505
    Re: Kurlon
    Looking at Bazaaz's instructions, for all CBR600RRs they show jumping onto all 8 injectors on the bike. You should have a grey connector coming off the Bazaaz harness for that injector. Grab the wiring off the injector next to it and chase it back to the harness, then find the 'missing' connector.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    Re: Kurlon
    Kurlon should have his own sub forum on nesr haha
    Austin
    Re: Kurlon
    He does, its just called "bike maintenance".
    Zip Tie Alley #505
    Re: Kurlon
    Kurlon,
    How do we achieve peace in the Middle East?
    Re: Kurlon
    Well, the problem as I see it over there is the people... if we could just get rid of them all...
    Re: Kurlon
    Dude....
    ... Genius
    Austin
    Re: Kurlon
    It is literally the only thing coming out of here. I don't know what the fuck this stupid thing is.
    Zip Tie Alley #505
    Austin
    Re: Kurlon
    Wait ... theres another one. Pair control solenoid valve. Do I need that?
    Im pretty sure thats an environmental thing, so Im 99% sure thats been deleted.
    Zip Tie Alley #505
    Re: Kurlon
    If it's the Pair, Duke Nukem it. (After verifying there is nothing else required to be done when doing a PAIR delete on your bike of course.)
    Austin
    Re: Kurlon
    Like I said earlier, Im 99% sure its been disconnected previously, I just couldn't be 100% sure I didn't disconnect it when I pulled the radiator. Just wanted to make sure.
    Zip Tie Alley #505
    Austin
    Re: Kurlon
    Ok, next problem. So I got everything buttoned up, and back on. Turn power on to the bike, all is normal, put the kill switch to run, and there's a constant clicking from under the seat, fuse area. If I try to start the bike, it just clicks faster. What did I miss.
    Zip Tie Alley #505
    Re: Kurlon
    So... pop the seat off, identify what's clicking, we'll go from there?
    Austin
    Re: Kurlon
    Its coming from where the fuses are. You know I barely know what a fucking motor is, I dunno whats clicking.
    Zip Tie Alley #505
    Re: Kurlon
    Gotta be a relay of some type making the noise. Find noise maker, see what color wires are coming out of it, that info plus a wiring diagram will determine what it is and what it's trying / failing to do.
    Rochester, NH
    Re: Kurlon
    Too much oil?
    Roland Arsenault
    LRRS and USCRA #763
    Re: Kurlon
    Austin
    Re: Kurlon
    Its not the oil you motherfuckers.
    But its just weird, its not solely when I try to start the bike, but when there's power, and only when the kill switch is toggled on. Not when its toggled off.
    Zip Tie Alley #505
    Re: Kurlon
    A lot of stuff happens when you flip the kill switch. Fuel pump primes, the gerbils awaken and start running in their little wheels, etc.
    Austin
    Re: Kurlon
    Fuel pump does nothing, second I hit the kill switch on, just clicking. I think its the starter relay.
    Zip Tie Alley #505
    Re: Kurlon
    You have a dead gerbil
    Austin
    Re: Kurlon
    Fucking gerbils. Can I replace it with a hamster?
    Zip Tie Alley #505
    Jul 2014
    Central CT
    Re: Kurlon
    Hamster require more maintenance and are mean as f!ck. They're harder to tame.
  1. Kurlon's GS
    Last Post: 12-04-19, 09:00 AM
  2. Paging Kurlon
    Last Post: 05-20-14, 12:16 PM
  3. Hey Kurlon
    By Jim in forum Pit Area
    Last Post: 11-19-13, 10:16 PM
  4. Don't Mess With Kurlon...
    By "Dangerous" Dan K in forum Pit Area
    Last Post: 07-25-09, 12:22 PM
