Results 1 to 25 of 34
First Oil Change
    Work U HBerry's Avatar
    Nashua
    First Oil Change
    Hey all:
    Found this on a ZX-6R website, does this sound like the correct procedure to follow for my first ever bike oil change:
    Changing the Oil
    This is a simple procedure which everyone can do themselves. You need:
    - Wrench for the oil plug (17mm)
    - Genuine Kawasaki oil filter (FRAM PH6017a)
    - Four quarts of oil
    - Funnel
    - Pan for the old oil
    - Oil filter tang
    With exception of the very first 1000 miles, always use fully synthetic oil, I recommend Mobil 1 MX4T.
    1. Before you drain the oil, first ride with the bike for about 10-15 minutes so the oil is HOT and thin.
    2. Its not necessary, but its easier if you put the bike on a rear stand (if you have one).
    3. Put the pan under the bike, and remove the oil plug (17mm). Let it drain for about 20 minutes for all the oil to run out.
    4. You don't have to remove the fairing in order to remove the oil filter, but its easier and cleaner if you do (left side fairing only). First try to unscrew the oil filter by hand. If that doesn't work, just use an oil tang
    5. Wipe down the rim of the mounting hole where the oil filter was fitted.
    6. On the open side of the new oil filter is a rubber ring. Dip your finger in the new oil, and rub a little oil on this rubber ring. Then screw on the new oil filter. (FRAM PH6017a)
    7. Put the oil plug back in (if you want you can replace the washer with a new one, but it's not totally necessary), and fill her up with new oil.
    TIP: You can go to your local auto parts store and have them order the FRAM PH6017a filters for you, I would order three at a time, a years worth. If you don't know, I do not like giving money to dealers, the bike dealer sold the same filter for $11 that I got ACROSS the street from an auto parts store for $4.
    Do not forget to dispose of the old oil in an environmental friendly manner
    Thanks
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    First Oil Change
    Sounds about right.. As it appears you are going to be doing maintenence yourself I would buy the factory manual for you bike...it is well worth the money. If you get ti from the dealer it'll prolly run you around $65..mayeb cheaper online...
    Nashua
    First Oil Change
    Someone found a downloadable version from the 03 version, I would assume that is very similar if not the same to my bike, and I will likely use that!
    Anything else I need to do for the 500 mile tune up other than an oil change?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Manvile, RI
    First Oil Change
    I don't think so..but I'm not mechanic....I think they also do a once over to make sure everything is right... that manual prolly will say what needs to be done and how to do it..
    Just wait the the real mechanics to chime in...they'll let ya know..i'll stop whoring
    Nashua
    First Oil Change
    Haha sounds good. I want to go for a nice ride to maine on saturday but that will put me well over my 500 miles so I would like to do the oil change either early saturday morning or friday night.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    First Oil Change
    That sounds right.
    You probably know this, but make sure you put in the correct amount of oil. The owners manual that came with the bike will give an amount for an oil change with and without a filter change. Putting in too much or too little oil is bad. The manuals typically give the oil amount in liters instead of quarts, so be aware of that.
    While your oil is draining, take a few minutes to check the fasteners on your bike, such as bodywork fasteners, exhaust hanging bolts, foot pegs, etc. They are probably all fine with only 500 miles, but it's worth a quick check.
    Check the brake fluid levels, coolant levels, and top off the windshield washer fluid.
    First Oil Change
    that would be me
    YOU'RE WELCOME
    Nashua
    First Oil Change
    THANK YOU!!
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    First Oil Change
    crash squid elaineo's Avatar
    Oct 2003
    First Oil Change
    Wait -- crap -- rewind -- why is too much oil bad? Cuz when I did the oil change on my bike, the manual said to put in 3.5 quarts of oil. but walmart only sells oil in full quarts, so after i put in 3.5 quarts, i was left with half a quart of oil. Plus, i was putting the old oil in the empty containers, so i had half a quart of old oil that had nowhere to go, so i was like crap i don't know what to do, so i just dumped all 4 quarts of oil into the bike. i figured anything extra would eventually drip out somwhere?
    Walpole
    First Oil Change
    4 quarts in a bike That is what my truck uses. Might wannna double check that. Too much oil can be real bad BTW
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    First Oil Change
    I've had a coupla bikes that used damn near 4 quarts when changing oil & filter. Which, btw, is the only way to do it (oil AND filter, that is)...
    Alton Bay, NH
    First Oil Change
    It's bad because modern engines are sealed and the oil has no where to leak out. Too much oil will increase the pressure in the engine, especially when you have it cranked up around 10K RPMs. This increased pressure may end up blowing out a gasket somewhere if it gets too high. If there is way too much oil, the excess drag of the engine components slogging through the oil will decrease performance and will lead to long-term engine damage. In my (non-expert) opinion, I wouldn't panic over an extra half quart, but I would get it out of there pretty soon. You need to either carefully let the half quart of of the drain plug (which can get messy and tricky to get only half quart out) or a better idea is to get a $2 plastic turkey baster at your local K-Mart and add on some plastic tubing if necessary. You can then suck the extra oil out of your filler area. You could also rig up something with a left-over hand pump from an empty bottle of hand creme and some plastic tubing to pump it out of the filler area. Next time, save the extra oil for your next oil change...you will only need to buy 3 quarts ! Put the extra old oil in a milk jug or something.
    Nashua
    First Oil Change
    What type of oil would you all recommend for my first oil change also?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    First Oil Change
    I'd run whatever the manual tells you to put in it...
    As a general rule of thumb, it's been my experience that you use 'dino' oil for the first coupla oil changes (unless otherwise specified by your manual), then switch to dino/synth blend...
    That's the way I've done it on any brandie new bike I've owned...
    Nashua
    First Oil Change
    Yeah it says non synth oil for the first 3 oil changes, just wondering if anyone recommended anything specific
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Nashua
    First Oil Change
    Also, if I were to go, say 600 miles because I drive to maine and back on saturday, instead of the stated 500, would that cause any issues?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    First Oil Change
    No. No worries...
    Raymond NH
    First Oil Change
    Spectro oil works OK and will not void your warranty since it is JASO-MA certified. Kawsaki oil sucks.
    Don't over tighten the drain plug. It's a big bolt going into soft metal. A torque wrench would be a great investment if you have any doubts in this area.
    There should be a sticker near the oil window on the engine with three oil cpacaity values on it: Oil only change, oil and filter change, and "brand new dry engine".
    Service manual is only $40 or so and worth every cent. There will likely be many loose fasteners on your bike. Check all that you can see, including the header mouting nuts on the head.
    Good luck!
    Nashua
    First Oil Change
    I have the service manual. I also have every tool known to man kind available to me. I will be checking everything.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Raymond NH
    First Oil Change
    You been visiting my garage at night??
    Nashua
    First Oil Change
    No but its nice to have a girlfriends dad that has been working on cars sense he was 14.
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Raymond NH
    First Oil Change
    or a wife. I had a pretty good selection of tools and then inherited a ton more when my father-in-law passed away. He was a gearhead out in CA for years during the hotrod craze. The tools he left me are amazing. He was also a cool guy to know. Miss him...
    Oct 2003
    First Oil Change
    Don't use cheap walmart oil like I did. i used to think that all oils were the same, but after i put in fully synthetic oil that i got from walmart, it started running and shifting like crap. it made my cam chain start rattling too.
    the previous owner had never ever changed the oil, and the bike was running great when i got it. ugh.
    mobil 1 is good stuff.
    Nashua
    First Oil Change
    Ok so i am right now changing my oil, do I need to change the filter for the 500 mile tune up or not?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
  1. Oil Change
    By KillahTillah in forum Bike Maintenance
    Last Post: 04-11-14, 06:40 PM
  2. Name change??
    By EFD 05 1K in forum Site Info & Suggestions
    Last Post: 06-25-10, 04:34 PM
  3. WAP change
    By jcbell1007 in forum Site Info & Suggestions
    Last Post: 06-25-09, 10:47 AM
  4. Oil change
    By amajew in forum Bike Maintenance
    Last Post: 08-21-07, 05:13 PM
