Results 1 to 9 of 9
Oil Leak
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Oil Leak
    I have a persisitent small oil leak that I just can`t seem to find. So far I have relaced a hose and oil cooler which I know had a leak in after I ran over something in the road. Now the oil leak left is just barely leaking but blowing around accross the bottom of the engine. I`m thinking of using the automotive dye designed for detecting hard to find leaks. Has anyone used this on a bike motor. Whats the + /- on doing this? Any Ideas would be greatly appreciated. Thanks.
    Banned G21forme's Avatar
    Lakes
    Re: Oil Leak
    Sounds similar to what happened when my valve cover gasket failed.
    Re: Oil Leak
    same here. knowing what bike might help though
    Jan 2009
    Wilmington MA
    Re: Oil Leak
    1997 ZX11. I`m thinking its either the oil pan on the right side or the oil seal on end of the balancer shaft which I have to split he engine cases to repair. Guess what I`m hopeing the dye will tell me.
    Posting Freak Scottg22's Avatar
    NH
    Oil Leak
    Another way is to spray foot spray (the white powderized kind) in the gasket or seal you suspect is leaking.
    Spray it on a clean dry, surface them let the bike run or ride it. If its leaking it will show up in the powder as brown.
    Jan 2009
    Wilmington MA
    Re: Oil Leak
    great idea!
    Lakes
    Re: Oil Leak
    Good luck, when you said bottom of the engine I just assumed it was the front. The foot powder idea is killer though!
    Raymond NH
    Re: Oil Leak
    If it is the balance shaft seal, you typically do not need to split the case to replace it. Simply drive a pair of drywall screws into the seal, 180 degrees apart and tug it out with pliers. Press/tap the new one in with a deep socket.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Oil Leak
    Quote Originally Posted by Scottg22 View Post
    I think my foot is leaking oil.
  1. TTR 125 Fuel leak
    Last Post: 04-19-12, 09:13 AM
  2. Help gas leak :(
    By sliceypete in forum Bike Maintenance
    Last Post: 06-21-11, 02:01 PM
  3. CRF450x oil leak
    By CRF450F150 in forum Dirty Bastards
    Last Post: 11-02-07, 07:54 PM
  4. Oil leak
    By jimaug87 in forum Bike Maintenance
    Last Post: 08-15-07, 08:34 PM
  5. Leak down tester
    By KB in forum Bike Maintenance
    Last Post: 07-20-04, 03:51 PM
