Guys,
If you get a new ball bearing for the rear wheel of your bike, what type of grease are you supposed to use in the ball bearing? Reason I ask is the stock bearing has this jelly like grease that is clear but has a pink hue to it. It's definately not "regular grease". I'm guessing its grease specifically designed for ball bearings?
Typically when a job calls for the application of grease I just use Mobil 1 Synthetic Grease:
http://www.mobiloil.com/USA-English/...ic_Grease.aspx
According to Mobil 1, it can be used for Ball Bearings. Thoughts????
