I changed my f/r sprockets and now my bike has a hard time shifting. I thought I might have put the front on backwards ,so I switched it and the same thing . also when the bike is in neutral the rear spins up,feels like the clutch is constantly grabing. I am out of ideas and patience. anyone?
If money is the root of all evil,
why do churches beg for it?
New sprockets shouldn't have anything to do with the symptoms you have.
Sounds like your clutch adjustment is out of kilter. You will probably have to adjust your cable so the clutch completely disengages when the handle is pulled in. As you have discovered, it is damn near impossible to shift a bike when the transmission is loaded.
Play with the cable adjustment first and then get back to us.
the bike was fine before I touched the sprocket. I never even went near any clutch adjustments.
how tight is your chain?
Brent LRRS #772
2006 KTM 560 SMR
Originally posted by oreo_n2
how tight is your chain?![]()
I bet it is too tight.
the chain was not even tight yet . I brought it to THE PIT STOP,and tony who knows my bike had no clue,yet.
bent shift rod!!!!! from having the rear off the ground and in gear and put impact gun to countersaft nut.
expensive mistake.
D'OH!
Brent LRRS #772
2006 KTM 560 SMR
ooohhhh, shitty. How much is that gonna cost ya?
aprox- $600 labor. dont know how many of the 3 shifters are bent but approx $45-50 each. while I'm spending the money and have the motor out Im trying to think of mods to do.hehehe
First off that sucks
Secondly WTF was you thinkin with the impact? Damn that sucks dood.
You need to pull the engine to fix that?
Good luck brotha.
the bearing behind the case and the (washer) that was behind it was locked on the shaft also 3rd/4thgear need replacing.
so-- lesson learned. don't take off front sprocket with rear tire in the air and in gear.
Why not? Thats how I did it, except with a breaker bar. Tell your transmission to not be such a pussy.Originally posted by double agent
so-- lesson learned. don't take off front sprocket with rear tire in the air and in gear.![]()
That sucks Chris, big money for a little mistake.![]()
04 ZX-10R
02 CBR600 F4i (track bike)
68 Oldsmobile 442
05 Tahoe
So I'm assuming the correct way to do the front spocket is with both wheels on the ground and in neutral?Originally posted by double agent
I usually don't mess with the front spocket. But it would be nice to know.
you are lucky too..that is absolutely the wrong way to do it....have someone step on the rear break or sit a 2x4 in between the swingarm and a spoke....Originally posted by JeffL
Why not? Thats how I did it, except with a breaker bar. Tell your transmission to not be such a pussy.![]()
very $$ mistake to make...sorry to hear
yeah, I was one step ahead of myself. good idea red about the 2x4 I will use that next time.( by the way spell check)
break or sit ?
I use the 2x4 method myself.
Works mint guy!!!!
