Results 26 to 50 of 90
where to start?
    san fran
    Re: where to start?
    there is a little latch at the front of the cap cap (12 o'clock position as viewed from the seat) if I recall correctly. You might be able to push something in between the tank and the cap to get it to open but I'm not sure.
    ill look at it closer tonight. if i end up beating the shit out of it to get it off, it wont matter, i can get another one for cheap. theres plent of ex's being parted.
    Tuono
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: where to start?
    Quote Originally Posted by catch2otwo View Post
    You should be able to pop it with out too much damage.. then drill the tumblers out so you can open it with a screwdriver.
    Posted by Jane in BoxChat
    Nov 2007
    Re: where to start?
    Take the whole gas tank to a locksmith. Bring proof that the bike it yours. It will take him 5 minutes and he'll probably do it quite cheap since he won't have to drive anywhere.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Westford, Ma
    Re: where to start?
    Quote Originally Posted by ceo012384 View Post
    My thoughts is there should not be a key on a race vehicle... lose it and your F'd ( like now )
    Nov 2007
    Re: where to start?
    yeah i'm going to be taking off my ignition and gas cap lock
    LRRS/CCS #103
    Westford, Ma
    Re: where to start?
    I liked that idea of the killswitch instead of a key.
    my racecar had toggle switches
    Senior Member FTMS's Avatar
    Warren, NH
    Re: where to start?
    Replacing starter brushes isn't a big deal. They just require some patience putting the armeture back in. Pay close attenion to the orientaion of the starter brush plate. There are notches for alignment. Get a set of dentist picks to help hold the brushed out of the way when you slide the armeture back in. This is a real pain in the ass or you get it first try. Most brush kit run about $35-$40.
    2004 Honda VTR
    1998 Honda VTR (Track Bike )
    1990 Honda CB-1
    1973 Yamaha RD350
    http://www.ftmsnh.com
    san fran
    Re: where to start?
    its not that i didnt get a key or dont want an ignition thing. when i got the bike the key was broken off in the ignition and wasnt given any spares. no big deal. got the gas cap off last night via screw driver. tank looks a bit rusty but i guess nothing out of the ordinary for being over 10 yrs old. also pulled the ignition off. next step will be to wire the ignition into the kill switch by the idea mentioned above.
    took a quick glance at the ignition last night, theres definately more then three wires on the back side. hopefully that manual has a wiring diagram.
    Tuono
    Re: where to start?
    there is a little latch at the front of the cap (12 o'clock position as viewed from the seat) if I recall correctly. You might be able to push something in between the tank and the cap to get it to open but I'm not sure.
    I'm fairly certain the latch won't budge unless the key is in the lock cylinder, allowing the cylinder to turn... Afaik there's only one way to open the cap w/o a key and that's with a screwdriver and hammer..... On the plus side, the latch will still open and latch normally after you do it, you just use a screw driver instead of the key.
    Re: where to start?
    The extra contacts on the bottom of the ignition are for the lights and prking light.... Can' remember which is which though. Shouldn't be too hard to figure it out though through trial and error.
    san fran
    Re: where to start?
    i figured thats wut they were for. time to break out the test light. god i hate electrical work
    Tuono
    Lifer Pittenger5's Avatar
    Austin
    Re: where to start?
    PS. if you get to the point you wanna convert it to a 17" wheel I got a spare swingarm
    Zip Tie Alley #505
    Warren, NH
    Re: where to start?
    It looks like if you jump the yellow and white wires from the 6 pin connector from the key switch this should give you power to the stuff that you want and let you turn everything on and off with the kill switch.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
    san fran
    Re: where to start?
    Quote Originally Posted by FTMS View Post
    so just connect the yellow and white wires coming from the key switch together and the kill switch will automatically act as the on off?
    Pitt: what else is involved with a 17in wheel conversion besides the swingarm change. i imagine, you need a new rear brake mc, new wheels, new front end?
    i tried using the ex500 forum and the people irritate me like nothing else. so ill be asking you ex experts for help from now on. thanks for all the info so far
    update: got the gas tank off, emptied all the gas. tank insides are in alot better shape then i thought. cleaned the petcock. took the ignition, dash, and fairing stay off. going to need a gas cap. anyone got an extra i could buy?
    Tuono
    Warren, NH
    Re: where to start?
    The key switch and the kill swith a wierd in series. Once the key switch has power it then goes to the kill switch.
    The wiring diagram in the Clymer manual link, that is in this thread is what gave me the color combo. Wiring isn't that bad, it is just a pain in the ass.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
    Nov 2007
    Re: where to start?
    That's pretty much always the case, right? So you could just take the hot line coming into the key switch and connect it to the hot side of the killswitch after removing that wire, eliminating the connection in between, and move one wire back at the harness, yeah?
    All the wiring is already run for you it seems
    Maybe I'm missing something though.
    LRRS/CCS #103
    Warren, NH
    Re: where to start?
    You got it. This will give you everything you need to run the bike.
    You can run into problems with the saftey switch circut on some of the newer bikes. You may need to put that circut to ground or it will work fine if it is left undone. The other thing you can do is bypass it at the CDI.
    2004 Honda VTR
    1990 Honda CB-1
    1973 Yamaha RD350
    san fran
    Re: where to start?
    i see it now that i have the manual. ill look at it tomorrow.
    Tuono
    Austin
    Re: where to start?
    For the 17 inch swap you need a new rear swingarm, new rear caliper and master, and a new front end, I think everything else bolts right up, I could be wrong though
    Zip Tie Alley #505
    san fran
    Re: where to start?
    is the only reason to switch to a 17 inch wheel is for tire selection or is there a performance aspect im missing.
    Tuono
  21. #46
    Austin
    Re: where to start?
    Tire selection. The tires for a 16 inch wheel are VERY limited, and more touring oriented. Theres at least one guy who still races a 16 inch, but he's a slow novice, basically just out having fun. Anyone competitive is on 17s
    Zip Tie Alley #505
  22. #47
    Re: where to start?
    Hehehe... The performance aspect IS the tire selection. Pirelli sport dragons or Dunlop GP501's (think that's what they were) are about a good of a 16 inch tire you're gonna find and they fall well short of the 17 inch tires that are on the market.
  23. #48
    san fran
    Re: where to start?
    gotcha. ill get everything up and running first and then worry about making the conversion.
    Tuono
  24. #49
    Re: where to start?
    werd. Good plan. Right now the 17 inch conversion is the least of your worries. Gwt it in top knotch condition first.
  25. #50
    san fran
    Re: where to start?
    k so here goes, ive done enough research and gathered enough info from you guys to at least get this thing started.
    so heres what it starts out as. 88ex500 non running, sat for 2 yrs
    11/23/08
    pulled the tank off. drained old fuel. have new gas cap assembly coming in the mail. have ignition off, going to rewire to have kill switch assembly act as the on/off switch.
    question:
    1. will an automotive tachometer work? id like a small 2 3/4 tach from say autometer or the like instead of the whole dash. will these work? more pics to follow with progress.
    2. to bypass the ignition. ive looked up the wiring schematic and a little lost. i have a brown wire (horn), white wire(regulator), yellow(goes to red/yellow wire on engine stop switch) , blue ( goes to blue/red on junction box), red (tail light), black/white(ties back into white wire), and orange/grn (turn signals). now someone said if you jump two wires to keep the kill switch "hot" then you will not need a key. exactly what wires am i jumping here?
    Tuono
  1. 636 won't start
    By apollomx681 in forum Bike Maintenance
    Last Post: 08-18-08, 09:39 PM
  2. Wed, 7/9, start in RI
    By jeantarrou in forum Rides & Events
    Last Post: 07-08-08, 07:49 AM
  3. start um up let um run
    By beet in forum Bike Maintenance
    Last Post: 12-17-03, 07:47 AM
