Hey just wondering what people do that store their bike in a garage or whatever over the winter that see freezing temps. The bikes on the track need to run water in the cooling system so do you just drain it over winter or put in a water/coolant mix while it sits?
My mx bike always has coolant (not straight water) and I haven't had an issue storing that and having it freeze/f up the bike.
thanks
LRRS #399
MX #505
sounds good to me..just wanted to double check and not kick myself for not draining it dry or something.
LRRS #399
MX #505
I was wondering the same, my garage doesnt get to freezing, but I've always just put coolant in the race bike, but itd be a million times easier to just drain it, is there any harm in leaving it drained?
Problem with coolant is you hafta flush it next season again. Leaving it drained would just be a lot easier.
Oddly, straight coolant has a higher freezing temperature than coolant mixed with water. Ethylene glycol, the chief ingredient in anti-freeze, freezes solid at 8 degrees F. See: ETHYLENE GLYCOL and look for "melting point" under "physical and chemical properties". When mixed with water at 50/50, it should remain liquid to at least -40 degrees.
Problem with just leaving it drained is that there may be a pocket of water that does not drain out. Found this out the hard way with my boat engine... To be safe, drain the water and fill the cooling system partially with RV/Boat storage anti-freeze. It's non-toxic so disposal is easy, and cheap.
Yup...drain the water/water wetter mix and use a 50/50 anti-freeze (most coolant you buy is pre-mixed anyway). I run engine ice in the street bikes all year, but for the race bike, I just use some cheap mc anti-freeze since it gets changed anyway before the bike gets run again.
perfect...thanks guys
LRRS #399
MX #505
Switch to Engine Ice or some other non-glycol coolant, and leave it in there year round.
FYI make sure when you are mixing your coolant that you are using Deionized water because if you dont your radiator will rust over time. When I got my trumpet the idiot before me didnt and I had to flush the system 4 or 5 times to get it clear. Then I just put engine ice in.
2006 Ducati Monster S2R800
Leave water wetter in and store bike in living room![]()
Same applies to street bikes? What should one do with the street bike? Should I change the coolant I have right now or keep it and change it in beginning of next season?
Sold: 1999 Kawasaki ZX-7R
2005 Pulsar 180 DTSi
Owning: Pulsar 220 DTSi
http://www.dhairyagupta.com
http://bostonbiker.blogspot.com
mine camps in my bedroom for the winter
"Chatbox...It's like Vegas, for your fingers."
Originally Posted by CBR_Knight
in my own thread, let me post this:
first of all, nothing about sex or play with a female seems interesting or arousing to me....
"BALLS" is coming home late after a night out with the guys smelling of perfume and beer, lipstick on your collar, slapping your wife on the ass and having the balls to say "you're next!"
Haha, do you always leave the TV on for the bike to watch when you aren't home?![]()
1986 Yamaha FZX700S (the original Fazer)
