Re: Another stuck oil filter...
Quote:
Originally Posted by
ceo and a bunch of numbers
That guy should work, i've used one of those with great success before on a too-tight filter...
:plusone:
That gets tighter on filter as you try to crank it off
Eric Baker
Eric dropped by this morning and this oil filter-removing god of a tool spun it right off on the first try.
Thanks Eric- and everyone else for the suggestions.
Just in case anyone finds this at another time, 5 minutes ago I just tried using a piston ring compressor to take the oil filter off my sister's FZ6 and it worked like a charm!
First time trying this method and it ended up working great so I figured it was post-worthy.
bergs
This is a really good idea. :wub:
viva_brasil
Does anyone have a good oil filter clamp tool that works with smaller oil filters?
I got the smallest one I could find at advance auto parts, and it has to tighten all the way to get a grip on the filter. I only have so much room to add rubber stuff as a damper...
If I could keep the handle on the filter clamp straighter, it would do more twisting and less denting/pushing...
I use a oil filter cap made for a Hyundai.
