Anyone doing tires up my way? It seems the guy in Medford is no longer changing tires. Last time I had some done it was by Tricky Mike. Guess I have been out of the game for a while!
If not I will probably go to the guy in NH, figured I would ask.
Tricky did mine this past fall in Chelmsford. Very easy to find and very reasonable price. In and out in under an hour.
I'm going to Medford! Tricky must be busy - I never heard back.
I had PM Tricky Mike just recently to see if he still was changing tires. He replied that he has stopped... :-(
I am going to go to Westford Auto Service (they are a bike shop although the name does not indicate that); they are at 44 Park St, Ayer, MA 01432, (978) 391-4790 They had quoted $50 per wheel to mount /balance (more than Mike, I know.. but they are a local shop run by a Veteran that I like to support).
The motorcycle inspection station in Littleton also does tire changes for bikes along with inspections. (do not have their contact info or prices handy but you can find via the DMV site).
Forgot to add...
It also may be worth it, to check out local motorcycle inspection shops - they usually repair /maintain bikes and I have found that if you give them some work you can negotiate a deal.
