Results 1 to 13 of 13
Kawasaki/Triumph valve shims
    Posting Freak tonup's Avatar
    Feb 2008
    Alton nh
    I have heard that some Kawasaki and Triumph engines use the same size diameter valve shim. Does anyone have a shim diameter # of a Kawasaki shim so I can compare it to the triumph. Trying to save major road time not to mention triumph is probably marked way up compared to kaw. There aught to be a trading system for these things. But then I quess the dealer wouldn't make their cut.
    Posting Freak
    New Hampshire
    Re: Kawasaki/Triumph valve shims
    There are a few companies that make shim kits. I know Hot Cams does and I think K&L.
    they may have a guide as far as different shims go.
    Raymond NH
    I have a Kwak kit. They are 7.48 mm (aspirin sized). I'd be happy to trade shims.
    Raymond NH
    I looked it up, my shims are way too small for your bike. Pretty sure you need 25 mm shims.
    Feb 2008
    Alton nh
    yeah! I got bigguns. Maybe I need to post my size first, Haah! Seriously, I heard they are identical, depending on motor. Figured I'd try here first..
    Littering and........
    Jul 2004
    Vermont
    I had a Triumph Sprint with the 955 motor. The mechanic I had do the valves advised me that he used shims from a Kawasaki.
    Sorry I cant be much more specific.
    Feb 2008
    Alton nh
    They are the 25mm and many bikes use the same size. Kaw's, Hondas, even some cars. Now I'm on the hunt for a shop to trade with once I get my cams off and find what size I've got where. Too stupid to save my drawings from last time.
    Dec 2005
    Near The Dragon
    Quote Originally Posted by tonup View Post
    do you have shim over bucket or shim under bucket design?
    the break point was around 02 i think
    shim unders are much smaller diameter
    Get out while you can
    Find your own path
    Feb 2008
    Alton nh
    Over de bucket.
    Dec 2005
    Near The Dragon
    those i am less familiar with..
    there is a triumph dealer right across the river from me though.. not sure if that helps you
    Find your own path
    Feb 2008
    Alton nh
    Japanese brand dealers are a plenty around the lakes region and with some scouting I'm sure there is a mech or dealer willing to swap shims. Hell, it would save them money due to not having to stock unnecessary inventory they may never sell.
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    What model of Kawi? 25mm seems awfully big for a shim-over-bucket design
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
    Feb 2008
    Alton nh
    Not a kaw. Its a vertical twin trumpet, 900. 865 but who's counting.
  1. Triumph valve check
    By 01xj in forum Bike Maintenance
    Last Post: 10-06-20, 02:41 PM
  2. Shims to swap ? Kawasaki/Suzuki/Honda 7.48mm diameter
    By scootertrash in forum Bike Maintenance
    Last Post: 11-07-17, 04:24 PM
  3. Where to buy shims?
    By lopycam in forum Dirty Bastards
    Last Post: 05-31-11, 10:06 AM
  4. Kawasaki Versus v. Suzuki DL650 v. Triumph Tiger
    Last Post: 04-15-08, 05:46 AM
  5. valve shims
    Last Post: 09-24-07, 01:37 PM
