Results 1 to 16 of 16
valve adjustment
    Carlsbad, CA
    valve adjustment
    So I'm at the end of my bike's break-in period and need to get it to a shop for the 1,000 mile service. I'm fairly certain that they adjust the valves as well as other things (oil, oil filter, etc). My question is, will I notice a difference in the way the engine runs, such as it having more torque, better throttle response, smoother running engine... or is the adjustment too minuscule to notice?
    I'm not a huge gear head even though I like to tinker around with things, but I'm fairly certain this above my head anyway. Just curious. Thanks.
    Jun 2005
    Re: valve adjustment
    Valves are likely shim and bucket and within spec, so I wouldn't expect any difference at all. What bike?
    Carlsbad, CA
    08 R1
    Jun 2005
    Yep... shims. I'd expect them to check the valves, but I wouldn't be surprised to see 20,000 before they actually need some adjustment.
    Carlsbad, CA
    oohhhhh... umm, shims? huh?
    The only thing I've ever used shims for is carpentry...
    Jun 2005
    I'd avoid putting those kind of shims under my cams
    Checking Valve Lash - Feature Review - Motorcyclist Online
    Carlsbad, CA
    good stuff, thanks for the info. If all I need to do to it for this service is oil and oil filter... I might just do it myself and save the labor charges!
    Lifer BostonSVkid's Avatar
    Dec 2005
    The valve check probably doesnt need to be done until 15k miles. Just change the oil etc and you will be set.
    2006 Ducati Monster S2R800
    Senior Member MattyC's Avatar
    Apr 2008
    South Shore, MA
    Nilez, your R1 won't need to have a valve adjustment for 26K. One of the benefits of owning a proper bike.
    --Matt
    Carlsbad, CA
    Quote Originally Posted by MattyC View Post
    --Matt
    hahaha, agreed... never heard it called proper before, I like it.
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    --Matt
    Real bikes would have had their valves adjusted about 4 or 5 times in that many miles
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Dec 2005
    Quote Originally Posted by BCT748 View Post
    Well italian bikes dont count! haha
    Lifer R1's Avatar
    Somewhere you dont know...
    My bike would have had their valves adjusted about 4 or 5 times in that many miles
    Fixed!
    Nilez - check your owners manual in the back, it lists everything you should do for the break in service.
    dont waste your money$$$$$$
    I did and its stuff you can do in your garage in a couple of hours.
    Apr 2008
    Salem NH
    R1SlowFlyer- Don't start with Yamaha vs. Ducati
    It's not my fault you settled for an R1
    Lifer R1's Avatar
    Your motor won't need any valve adjust for at least 25k.
    FWIW; I bought my FZ brand new and when I checked the valves at 26k, I had 3 exhaust a smidgen on the tight side...which I found to be odd, but nonetheless, every thing else was well within spec.
    Yamaha did good on the R1 motor.
  1. SV-650 valve adjustment
    By NPDCPA in forum Bike Maintenance
    Last Post: 06-22-16, 09:00 AM
  2. valve adjustment
    By j4eric in forum Bike Maintenance
    Last Post: 06-30-11, 02:25 PM
  3. Valve Adjustment
    By emayn15 in forum Bike Maintenance
    Last Post: 03-13-11, 05:22 PM
  4. Valve Adjustment
    By csmutty in forum Bike Maintenance
    Last Post: 12-31-09, 11:32 AM
  5. Valve adjustment?
    By capt1014 in forum General Bike Related
    Last Post: 06-17-08, 09:03 AM
