Results 1 to 25 of 29
Dear Go Pro
    Lifer Pittenger5's Avatar
    Austin
    Dear Go Pro
    Dear Go Pro,
    Your cameras are fun little toys. The video they take are interesting and helpful. I like watching them. However, your stupid mounting system leaves a lot to be desired. I have literally used your camera about 6 times, and more than 1/2 of the times I've had incidents.
    Incident 1 (First time I used the camera). The screw backed out and the camera fell off the bike. Fortunately, we managed to find the camera and it came out relatively unscathed aside from some scrapes and scuffs. I will also not hold you responsible for this since I might not have tightened it enough.
    Incident 2: I tightened the fuck out of the screw, and cracked the clear case. Fan fucking tastic. 40 bucks to order another one, or do I risk losing it again? Fuck it, Ill fix it.
    Incident 3: The screw backs out AGAIN and I lose the nut part, but at least I see it before I lose the camera. Lovely.
    Incident 4: I dont over tighten it, but enough so that it doesnt slide around, and put some locktite on the screw so the nut wont back off again. Get back home, camera intact, take it off the bike to get video footage. Somehow the black mounting part has broken. Into chunks. Theres black plastic chunks everywhere.
    So dear Go Pro, maybe I'm an idiot or unlucky or maybe its you. Either way, I am not happy. (well which one am I then!)
    Zip Tie Alley #505
    Re: Dear Go Pro
    Nylon lock nuts maybe?
    Member tdiloren's Avatar
    Oct 2008
    Maine
    Re: Dear Go Pro
    I had a problem with the mounts two summers ago. It broke and the thing fell off the bike. I contacted them and they sent all new mounts. No problems since.
    Dec 2003
    Ma
    Re: Dear Go Pro
    I've had no problems.
    Re: Dear Go Pro
    Richie... you're an idiot. Actually, I find their mounts a little bit awkward. It helps a lot to use a phillips head screw driver when tightening the bolt, Which makes the finger screw a bit misleading/useless.
    Posting Freak Scottg22's Avatar
    NH
    Re: Dear Go Pro
    GoPro was great to me when I opened my HD Hero and broke the battery door cover. Snapped the tabs off of it with my thumb. I contacted, they sent a new one.
    Did you contact them?
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    Re: Dear Go Pro
    Just got mine this year. You can bet I will tether the mount and camera untill i know how things hold up. Thanks for the heads up Pittinger5
    AF Member REXXX's Avatar
    Tampa, FL
    Re: Dear Go Pro
    the only problems i have had with mine is the actual mount that you put on the helmet or flat surface. I have crashed a couple times and the plastic mount broke even though i never hit my head haha. and that its corrupted a couple of my SD cards.
    2000 RC51
    Re: Dear Go Pro
    Is this the same thing Mark & Todd have? I thought they were pretty fuggin' secure. Who said Richie's an idiot?
    Re: Dear Go Pro
    what junk...those assholes at GoPro owe you reparations!
    I'll pm you with my address and you can mail it to me to take this cursed blackhole of headache off your hands
    Re: Dear Go Pro
    Nope, Todd had the Contour HD, I had the Contour HD GPS
    Re: Dear Go Pro
    Very well then, carry on. Pitty's still an idiot though, right?
    Austin
    Re: Dear Go Pro
    Yes, he's still an idiot, but I still think theres something wrong here. 3 different problems at 3 different times, either Im a complete idiot and always do something wrong, or theres something funny with the product. Maybe I just got a bad run or something.
    I have not tried to contact them, I will definitely try though.
    Zip Tie Alley #505
    Central MA
    Re: Dear Go Pro
    "Incident 4: I dont over tighten it, but enough so that it doesnt slide around, and put some locktite on the screw so the nut wont back off again. Get back home, camera intact, take it off the bike to get video footage. Somehow the black mounting part has broken. Into chunks. Theres black plastic chunks everywhere."
    You should be aware that Loctite can have this effect on some plastics.
    Austin
    Re: Dear Go Pro
    Really? This I did not know. Is there some other product that produces the desired effect without destroying the plastic?
    Zip Tie Alley #505
    Loctite will eat PVC type plastic. Use a plastic epoxy glue for plastic.
    Austin
    Re: Dear Go Pro
    Is that permanent or able to be removed and stuff though.
    Zip Tie Alley #505
    Quote Originally Posted by Pittenger5
    Permanent. I see what you mean. You meant threadllock? Was thinking you meant super glue.
    Austin
    Re: Dear Go Pro
    Nope, just something that will prevent the screw from backing out which happened twice, and wont eat the plastic like apparently happened once. Maybe I should take the hint and stop video taping my slow ass
    Zip Tie Alley #505
    Re: Dear Go Pro
    Use nylock nuts, which my Go Pro already came with? Those won't vibrate loose.
    Re: Dear Go Pro
    He's already got locknuts. Her name's Leeza.
    Re: Dear Go Pro
    So far I have brought my go pro surfing, motocrossing, mt biking, and snowboarding, I haven't had a single mount failure. It must be Richie's trouble with screwing...
    Re: Dear Go Pro
    I loled
    Central MA
    Re: Dear Go Pro
    You could try dabbing the screw with silicone type sealant. This should come off fairly easily. The "Plumbers-Goop" type adhesives are really strong and may give you trouble when trying to remove it. Same with epoxies and cyano's (superglues).
    Duct Tape?
    Lifer oVTo's Avatar
    Jun 2003
    North of Boston
    Re: Dear Go Pro
    Quote Originally Posted by Scottg22 View Post
    I did the exact same thing the first time I opened it and they sent me a new one no problem. No problems since then.
    DanG
    - Blaise Pascal
  1. Dear every cager...
    By butcher bergs in forum General Bike Related
    Last Post: 04-21-10, 07:30 PM
