Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 101 to 125 of 352
NHMS 2012 Suggestions?
  1. #101
    Lifer union's Avatar
    Blackstone, MA
    Re: NHMS 2012 Suggestions?
    Quote Originally Posted by brady View Post
    is it at the seam?
    Yes right about where the new pavement meets the old
    James
  2. #102
    With regards to the pavement:
    The track really needs to reconsider who is doing the paving, IMO.
    Between the issues in T2 with new pavement that was just put in which was recently ground down plus the other issues with the seams between the old pavement and the new stuff and finally the three-lane access road which is not smooth by any stretch of the imagination yet has new pavement....suffice to say the quality all around is barely lackluster and new problems are essentially being created.
    I say this as I'm looking at my road, which was recently repaved with a couple short sections that required some patchwork/ repairs, and I swear if anyone were to drive thru there with their eyes closed they'd be hard pressed to identify where the old pavement meets the new.
    Sorry for the ranting but I just don't get it.
    With all this time and effort being spent on making improvements to the surface just to have some other issue (or complaint) arise which requires more time and effort to go back and correct these certain new issues, why not just do it once and do it correctly the first time or get a company that can and will?
    Again, my apologies for the rant but I cannot wrap my head around why all this new pavement goes down which then requires additional work or has some other issue pop up within a year or so...
    #331 CBR929RE's Avatar
    Bridgewater, MA
    That or it's because he rides a frigging moto cross bike.
    I said I don't feel the bump either and I'm not on a motocross bike.
    Lifer Pittenger5's Avatar
    Austin
    Go faster
    Zip Tie Alley #505
  5. #105
    ask degsy. he knows where it is. i have to make sure im off the brakes before the seam or i get a big bang when i go over it. kinda like if your on the brakes too long going into 3
  6. #106
    The minor difference is your road doesn't hold SCCA events, etc...
    Are you taking suggestions form trackday riders or just racers?
    Tighten up your line as you cross onto the new pavement. Hit the point and it's a glassy smooth transition.
    For T3, how late is too late? Over the 1st transition? I trail past the rumble strip and to the point of the patch. Then I'm immediately back on the gas.
  9. #109
    I'm not sure what that's supposed to mean.
    Blindly tossing pavement at the ground of a racing surface then having to go back at least once to fix it within a year is the acceptable practice over taking the time to do it properly?
    Grinding a corner down (T2) within a year of new pavement being put in is acceptable?
    I can only hope that these 2nd and 3rd visits for repairs after the fact aren't being billed to the track...
    Just about any track that hosts car events has this problem in the turns, heavy cars at speed running sticky tires through a turn put a LOT more sheer loading on the pavement than you see on public roads. That's where all the rippling, bumps, etc come from.
    May 2007
    Southern NH
    I think the gate fees could come down. It's tough to ask people to come and hang out to the tune of $25 a head. Cheaper admission would certainly equate to more attendance.
    Seriously...
    I often lead a group of 15 - 25 folks up for the races and we're treated like a group of 25 one offs. Sometimes I just decide to go somewhere else.
    And if you want to draw more folks some PR about the Club Races would be helpful.
    Muhammad Ali.
  12. #112
    Bridgewater, MA
    but that still has nothing to do with NEW pavement that was put down as a bump.
    It wasn't put down as a bump, it just formed one quickly due to what I said above.
    Bridgewater, MA
    go take a look at the triangle of new pavement a couple feet off the apex of 2. that was put down higher than the existing pavement. its been like that since they first put it down and hasn't been fixed. cars had nothing to do with it. this is a perfect example of what Bergs is saying, they should have done it right the first time.
    the ripples in the braking zone into 3 were cause by cars so you can't blame the pavement company for that.
    Not with T2 or the bumps in T1 for that matter.
    The traffic is definitely playing a part however the rapid surface changes are a direct result of poor preparation of the substrate (the dirt).
    Please view the quality of the access road for further proof of what I speak.
    New paving company is my suggestion.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    There has been paving issues at NHMS since it's inception. I can remember NASCAR races red flagged because the paving would get ripped up in the racing line in the corners. They blamed it on flat track for 3400lb stock cars. The Drivers HATED the track for years.
    Posted by Jane in BoxChat
  17. #117
    Lifer lrrs313's Avatar
    Asheville, NC
    Bring back tight turn 10? At least for one weekend/season?
    This one's going to get flamed hard, I know a lot of people were really against it last time it was discussed. I still think it was a fun change to the same old track.
    -Brian
    15 S-Works Venge
  18. #118
    Jan 2010
    Farmington, CT
    Quote Originally Posted by lrrs313 View Post
    Only if there is a "dropped weekend" brought back...
    I remember seeing quite a few guys getting tangled together in the Tight 10, last time that we ran that. It wasn't the normal guys that you typically see pushing it to the limit and crashing... just victims/fallout of some yahoos trying to take every little advantage as possible by passing in an unsafe pass zone.
    IF they want to change what is currently there, then build a completely new and safe road racing track without walls. My 2 cents.
    Dec 2003
    Ma
    Eric, One word for spectator attendance.
    Groupon
  20. #120
    Quote Originally Posted by wheelieman14 View Post
    Yeah... don't think there's many of us out there that wouldn't like to see that. It's kind of a given
    Groupon
    Hmm. Interesting... Yeah, might be worth a shot.
  21. #121
    ive tightened up my line in 1. im way inside the orange box now. i did notice that the bump isnt always there. i just have to pinpoint where the smooth part is.
    as for 3, yes i believe it is the first transition. i think just as i pass the the rumble strip i try to get back on the gas.
  22. #122
    actually they ground that down. its much smoother now
  23. #123
    Word. If you look at the transition onto the new pavement in T1, aim for the point. It's smooth if you're within about a foot of it.
  24. #124
    Bridgewater, MA
    didn't even notice last week. if you're right up on the curbing it was always fine. it was just the closer you got to the point of the new pavement is where it got bumpy.
    well you can still kinda feel it....but you have to be going kinda fast :
  1. 2012 LRRS Suggestions
    Last Post: 10-03-12, 10:35 AM
  2. RRR 2012: Random Rhode island Rides for 2012 thread
    By FriskyDingo in forum Rides & Events
    Last Post: 09-03-12, 11:56 AM
  3. 2012 NHMS Dates - LRRS Practice and School Specials
    Last Post: 04-24-12, 01:55 AM
  4. GPS Suggestions?
    By Femmekat in forum General Bike Related
    Last Post: 05-26-10, 12:41 PM
