Helmet visor fogging fixes
It's getting to that time of year again. My morning commute was a tad nippy yesterday with a temp of 34F. A neck gaiter helped, but it impacts the air flow around the base of the helmet so my breath fogged the visor. (First year with a full face helmet.)
Fog-X? Any other options short of using a snorkel? :teehee:
Does your helmet have a breaht guard built in to it? that helps
or a fog free shield
i have had 2 scorpion helmets that had no -fog shields. worked great. but i crashed them both at the track. They did their job, no head damage, etc.
the no-fog shield on those were unbelievable
This works great
Respro Foggy Mask
check out street and comp they are $19.
I use it from Oct to April for sure.
I use Plexus and it does a great job, IMO.
Nothing's going to help if you're stoppedor going slow....that's when I usually take deeper but slower breaths and exhale downward thru my mouth. Basically I minimize my nose breathing as much as possible.
Fog City. Been using 'em for years...
Check this out ofr a gaiter (balaclava). This is what I use in below 50 degree weather and have used it down to 25 degrees and it's toasty.
Sugoi MidZero Balaclava
Its shell is lycra, so it's thin and wicks away moisture and its inner is a thin fleece, so it's warm, REALLY warm.
I also use a Respro Foggies and it works great directing breath away from the faceshield.
Turn your helmet clockwise 180 degrees. Its your breath that causes the fogging and you don't breath out of the back of your head.
Or you could try some of those other suggestions....
:lolup:
Leave it to Dave.
I think I'm going to spring for a Scorpion helmet and heated shield from sportbike track gear in a few weeks.
I've got a Nolan N-102 that came with an insert "fog shield." Tried it for the first time today -- it works wicked decently.
Nolan N102 - webBikeWorld
CAT CRAP!.............. NOT ACTUAL SHIT.. IT WORKS GREAT!
http://www.webbikeworld.com/r2/motor...isor-defog.jpg
use a snowmobile breath guard works wonders.
tatersalad
ask puppet how it works....lol
it works okif its just cold but if its muggy.. andits fogging... it s horribel and reallyhampers vision a lot.
McBiggity
+1 best i have seen.....
McBiggity
flag on the play. i call BS.:mrgreen:
All you need to consider is fog city. Works in absolutely all conditions.
I have one of those anti-fog liner things you stick to the inside of your visor, got it at Motomart, dont know what they're called. Never had a fogging problem for 3 years under I pulled the old one off and hadnt put the new one on. Its fogging like a bitch now, so I assume that means they worked well.
I highly recommend Fog City in that case.
bausch and lomb FOGSHIELD XP safety cleaner, got this at work for safety shields and glasses, works top notch ! does not have that halo rainbow mirror effect like some products with car or street lights.
around 4.00 per unit if ya search around....
Bausch & Lomb: FogShield XPョ Pre-Moistened Lens Cleaning Tissues
The FogShield XP Pre-Moistened tissues, created for extreme temperature conditions, cleans both glass and plastic lenses combining effective cleaning and extreme anti-fog protection.
