2003 CBR600RR Part Out On The Cheap!
Im posting this here first in case anybody wants anything, I can bring it to Loudon with me labor day weekend. Motor available shortly. Shipping Extra. May have other small misc parts available. Heres the list:
• Ohlins Triple Clicker Shock, hydraulic preload adjuster, set up for 170lb rider, 628lb spring, freshened in beginning of 2010 season by Thermosman, $550
• Straight Upgraded Forks, GP Suspensions compression valves, reworked rebound valves, .95kg Springs, valved by Computrack Boston, 170lb rider, $300
• Ohlins 20mm Supersport Kit, reworked by Thermosman Suspensions, good for 230lb rider, will fit most 20mm cartridges in modern sportbikes, $200
• Traxxion Dynamics Omni Fork Springs, 1.0kg for CBR600RR, may fit other forks, $50
• Scotts Damper, rashed but works fine, rebuilt end of 2009 season by Scotts, $150
• Scotts Damper Mount, for 03/04 600rr, $50
• PENDING SALEBrand new 05/06 600rr E-racings Upper, Lower, Tank cover, and (2) fenders, also fits 03/04, $200
• Aftermarket 03-06 600rr Vortex Fairing Stay, used for one race, never crashed, still has stickers on it, $125
• Full Hindle Exhaust, Titanium can, few small dents, and dented tip but didn’t seem to affect performance, $250
• Dynojet PCIII USB, 05/06 600rr, works with 03/06 600rr (just need to load 05/06 maps), $150
• Woodcraft Clip-ons, rashed but work fine, w/ new bars $50
• Pitbull Trailer Restraint Pins, good condition $50
• HRC 1/6 quick turn throttle tube, $25
• PENDING SALEStainless Steel Lines (Galfer I think) $30
• PENDING SALEWoodcraft Frame Slider Bases, $20
• Calipers w/ Vesrah RJL Pads, pads have 4 races and one track day, $75
• Front Wheel w/stock rotors, straight, gloss black, $125
• Front Wheel w/stock rotors, straight, semi-gloss black, $125
• Front wheel spacers, only had one set so I am selling separately, $5
• Rear Wheel w/ lightened rotor, straight, semi-gloss black, $125
• Rear wheel w/ stock rotor, straight, gloss black, $120
• Cush Drive & Spacers to go with one rim, $10
• Straight Axels, $10 each
• Subframe, may be very slightly tweaked, not noticeable if it is, $40
• ECU $50
• Frame w/ clean title, .4 degrees out of alignment according to computrack, can be straightened, $400
• Tweaked triple trees, can be straightened, $40
• Gas Tank, two small dents, Vortex Keyless Gas Cap, $100
• Main Harness, modified for race, works fine, $40
• 07/08 CBR600RR throttle housing, (used for HRC Throttle), good shape, $25
• 07/08 CBR 600rr kill switch, modified for 03-06 600rr harness to work with throttle housing, good shape, $20
• Throttle cables, small kink at mount, works fine, $10
• Clutch perch and Cable, small chips from pea gravel in T6 $10
• PENDING SALEWoodcraft Rearsets, pretty beat up but they work, good for spare parts also, $65
• Lockset, with gas cap, and key, $100
• PENDING SALEStock Seat, excellent condition $20
• Stock exhaust, excellent condition $40
All prices OBO! Most of these parts are still on the bike, and will be taken off the night of payment and shipped the next day. Ill be listing all this stuff on the WERA forum and 600rr.net shortly so let me know if your interested in anything. Pics are available by request of pretty much everything.
Re: 2003 CBR600RR Part Out On The Cheap!
How much for the whole front end? Wheel, brakes, triples, clipons and forks.
Degsy
Wirelessly posted (BlackBerry8530/5.0.0.734 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
How much for the motor? Pm me pls.
Doc
Pm sent to both of you :beerbang:
Interested in the ohlins shock, please pm details. Thanks
interested in bodywork. pm sent
Also a picture of the woodcrafts would be good
Humm... i might have to hit you up for a few things :)
Io-bot
Anything you want, as long as its not going to make you faster. :wink:
Added trailer restraint pins
Great meeting you at the track last race weekend.
you've got me thinking about a couple of things:teehee:
I could use some upgraded suspension, Steel brake lines and maybe a set of wheels???
nt650hawk
Nice meeting you as well Gino. You got me wanting a hawk now. Going to keep an eye out for something over winter time. BTW Your 600rr wants you to buy it a new shock, it will thank you :naughty
i looked on ohlins website and it doesn't seem that that shock will fit 05-06, i could be wrong but ohlins makes a different one for the 05-05 then the 03-04, major bumber, nice shock!
It will physically fit, I believe the change was made in the internal valving due to the taller geometry. Thermosman added a little rebound into the damping of the shock to compensate for the fact that I ran the bike 6mm taller in the rear so it should be all set if you just run the shock at the height I have it set at.
http://www.600rr.net/vb/showthread.p...lins+shock+fit
PM sent on a couple of items.
Bump last chance before I go to Loudon this weekend. Ill also be at monticello monday, and Jersey the next weekend.
Bump still have these parts available.
