Got a bunch of stuff for sale from my R6. Came off an 07 R6. All prices include shipping.
-Penske Triple just serviced by pete kates of GMD Boston beginning of last season, Its got a 575lb spring on it now, but I have a 520lb spring also I can throw on instead- $650 shipped
-Traxxion AK-20 extended 10mm or stock length whichever you want- $700 shipped. THESE WILL WORK IN THE STOCK 06-07 FORKS (where I had them) and extend them by 10mm. They also fit 08+ forks as they are technically the same kit. I have an 06-07 and this makes the bike hold a line a lot better, hence the change to longer forks in 08. Has .95 springs. I need your original compression valves and valve holder back. Ill send you the one from my forks, with the traxxion valves installed (see pic) and then all you have to do is screw the assembly into the stock forks. The kit also comes with the install tool.
-New in package 49 tooth sprocket from pitbull $45 shipped
-Hindle Full system, perfect shape, can has about 2 race weekends on it. Can was replaced because I had a ratty gytr on there, and it didnt fit that great so I got the hindle can for it. Has 02 sensor bung welded in for autotune which can be plugged $650 shipped
-ASV Unbreakable levers- Brake like like new, clutch side some scratches but good shape, waranty still in box, should you ever brake one of these levers ASV will replace it with a remanufactured one- $150 shipped.
-520 lb hyperco spring fits penske ohlins, elka, JRI, etc, $50 shipped
-Dynojet PCV- $190 Shipped SALE PENDING
-Dynojet Autotune and sensor- $180 shipped SALE PENDING
-Dynojet QEM- quickshifter module, comes with sensor that is sticking. Not sure why it could just need to be cleaned or its broken. Send it to dynojet and they can tell if it can be fixed, and they might even replace it.$100 shipped SALE PENDING
-NEW BT-003 RS tires, never been mounted, with the stickers, 180/120 size. $215 shipped.
The next couple parts Ill take for $10 a piece plus whatever shipping costs:
-Stock stator cover, rashed but functional
Pics in the process of being loaded. More pics can be found here:
http://rides.webshots.com/album/582661231JhnpHk
Most parts come in original box. All parts boxed up and ready to go.
