Gen 2 SV650 power loss in the rain.
Hey guys,
Yesterday at NHMS I was out during one of the wet races and my motor lost any power it had. Limped it into the pits... I've found some info online about a clogged drain for the front cylinder. Is there a remedy for this once I clean out the drain? Any sort of... shield?
Thanks!
Clean out drain and replace the plug cap... be sure the seal is in place the best it can be. Plug caps seem to be a pretty regular failure in the rain. I tried to have a spare for Sam's SV
Re: Gen 2 SV650 power loss in the rain.
X2 drain hole and new cap problem solved
TheIglu
Ah, the infamous SV325.
And here I was thinking I couldn't get any slower!
TheIglu
So what you're saying is, he can run it against R3s and RC390s?
number9
Paging Kurlon.
Gotta keep yer drain hole clean! :naughty
i had that happen once. i think pete passed me and gave me a wtf look
problem went away when i installed a fender
edit: just realized you said 2nd gen, didnt those have a plastic flap that covered the front spark plug?
nhbubba
Paging Kurlon.
CCS single cylinder blind spot gets you into just about every class other than anything Supersport, Supertwins, or Formula 300. You can run Ultralight 300 but your points will not count for the ROC in Daytona as you'd exceed the 310cc limit on singles in Ultralight Thunderbike.
SVRACER01
Yes, but that little flap doesn't do enough if it's wet enough. Water can still get through the radiator (and around the flap) and down onto the front plug.
SVRACER01
:lmao: I loled
