Re: New sprungs for the KTM!
sweet! you should def see a big improvement if you're that far off. bike will stay up in the proper part of the stroke over trail trash, etc. where the valving tends to be more plush ... rather than riding low where things stiffen up to help with bottoming.
look forward to the report!
Cracked into it tonight! Rear was SUPER easy! Took me 15 min, but I bet if I pushed I could do it in 5 minutes.
Stock rear spring: (2 bolts to get it out)
https://i.imgur.com/JPNRIVY.jpg
Out and into the vice. I had the shock tool to back the preload off until I could turn it by hand. Then a small circlip and slide the spring and washers off, no compressor needed!
https://i.imgur.com/ulQs4v5.jpg
New vs. Old
https://i.imgur.com/zyrxc3Z.jpg
New spring back in the bike @ 80 NM and blue loctite
https://i.imgur.com/0lqp2Ej.jpg
Got started on the front. Tire off, brake off, cracked the tops free while still clamped (glad I did, SUPER tight, 50mm nut), then removed forks and called it a night.
https://i.imgur.com/NGwn9SM.jpg
edit: Pardon the messy garage, it's dirty (dirt driveway) and full of rc cars and other stuff
Did the forks today in maybe half an hour.
https://i.imgur.com/WqMMEVH.jpeg
Feels so much better!
The PDS bikes are so nice to work on. My 150SX on the other hand you have to pull the swingarm to get the shock out. WTF KTM!?
Kurlon
PDS means no linkage?
I really thought i was gonna have to take it to a shop for the spring swap
xrocket21
Yeah, 'progressive damping system' or something like that is what KTM calls their linkageless bikes.
Kurlon
Well, I friggen love it!
You'll notice a massive difference. I too am significantly heavier than your average Austrian so I had mine reprung when I bought it. Compared to others I've ridden, right springs make a huge difference when you start pushing the bike.
ZX-12R
Thanks man, its like a whole new bike! I can thrash on it harder now.
I am finding I have to keep cranking and cranking rebound though, still think I can go stiffer front and rear.
