Results 1 to 17 of 17
RC51 Battery box help
    TWINS! xrocket21's Avatar
    Central Maine
    I have an aftermarket tail on my RC51 and I just cant seem to keep the battery in place. I dont have the stock tail to work with and I dont see any aftermarket stuff. Any RC51 guys on here run into this and have a good solution short of fabbing my own out of aluminum?
    Re: RC51 Battery box help
    Pics!
    Central Maine
    Pics!
    Id be embarrassed for any of you to see the current duct tape, tie wrap, broken plastic, safetywire rig that is in there now....
    Feb 2008
    Rhody
    I ended up "fabricating" one out of aluminum, I'm pretty much a hack with that stuff but it didn't look too awful. If you've got some extra cash to spend the battery relocation kits for 51's are pretty sweet. Actually, those probably wouldn't be a huge diy challenge?
    Hyper
    Central Maine
    Got any pics of your setup?
    I had never heard of the battery relocate, looks interesting, but I dont think I want to go that route.
    Feb 2008
    Rhody
    I knew you were going to ask! I definitely had pics of it, let me see if I can dig them up.
    Hyper
    I can 3D print one out of ABS, would need a dimensioned sketch
    Central Maine
    !!!!!!!!!!!!!!!!!!!!!!!!!!! that would be sick!
    Because batteries are rectilinear taking dimensions iseasy.
    Made this to use a Li battery in the TW200. Rev 1.
    This was made to test fit a replacement on the R90, which has a giant battery but modest electrical needs. I’ll replace the stocker when it wears out with another Li battery, maintain stock look and have storage space.
    Your timing is goidas Im going to be house-bound a while after surgery. The printer will do 8”x8”x6” in one build.
    Central Maine
    Well, i pictured something more complex, but it is tight and the subframe i pictured it hanging from is where the seat rests.
    RC51 Battery box help-20190819_165533-jpg
    RC51 Battery box help-battery-box-jpg
    This is what i was thinking, it should hook over the crossmember. The crossmember itself is 5/8", so maybe just a touch bigger. Maybe if the semicircle went like 200 degrees instead of 180 it would kinda snap on. The rear would just rest on the tail i guess.
    @garandman
    Central Maine
    Since I'm leaning toward a much simpler design, Im wondering if I should just try thermoforming some Kydex
    https://www.amazon.com/Plastics-2000...ateway&sr=8-10
    edit: Im kinda second guessing Kydex, with the v-twin setup the battery mount is kinda close to the rear header, it definitely gets hot under there, I wounder if Kydex would soften up...
    Kydex seems to have a Heat Deflextion Temperature of 150-170.
    3DP ABS is around 200.
    I suspect either will work.
    Central Maine
    RC51 Battery box help-20190823_162220-jpg
    RC51 Battery box help-20190823_162413-jpg
    Well, it went great. I got super thick kydex and made a pretty nice jig to form it. Seems to be working and hasnt softened up!
    Thanks guys.
    Feb 2008
    Rhody
    Finally got around to looking for some pics, unfortunately no luck... Your mock up looks pretty similar to what I remember mine too look like, what I also remember is finding a good spot for the ECU was a pain, and I secured the tipover switch and the fuel pump relay to the back of the tray. PCIIIr I'm not sure where that ended up, and at the time it was a track only bike so I didn't have any of the lighting relays.
    Hyper
    Looks good!
    3D printer doesn’t care about complexity. You can have variable wall thicknesses, any shape, doesn’t really matter.
    Jan 2014
    Connecticut
    @garandman
    You're not supposed to remove the tray when you put those on. I have had 4 RC51's you cut the whale tale off and a little of the bottom of the box keeping the sides. The whole idea is to keep the battery box. I have had 3 different undertail covers. You really need to just spend the $25 or $30 to get a cut battery tray. Stock ones are $$$$$ but you can get the cut ones all day. Otherwise you are making a lot of work for nothin...
    Central Maine
    Quote Originally Posted by Beinggodisgreat View Post
    I bought the bike used in 2008 and it was already gone.
    Im good with my setup now, works great!
  1. Which battery charger do I need for my marine battery in trailer?
    By xxaarraa in forum General Bike Related
    Last Post: 11-25-22, 08:50 AM
  2. Replies: 20
    Last Post: 05-22-19, 07:28 PM
  3. Battery Tender / Deltran lithium iron battery
    By SwiftTone in forum Bike Maintenance
    Last Post: 03-16-15, 06:00 AM
  4. Replies: 8
    Last Post: 11-30-09, 08:24 AM
