Page 1 of 4 1234 LastLast
Results 1 to 25 of 77
Questions regarding 2012 R6
    I have a track-prepped 2012 R6 being shipped to me in a few days and it has a couple things I want to sort out immediately after it arrives.
    One of the issues is that it has a CEL. It's either for the O2 sensor or the EXUP or both. Bike currently has an Akra slip on installed.
    Is there software that I can get ahold of that will allow me to make changes in the ECU? Something like RomRaider, for example. I haven't found a whole lot of info other than sending out to be reflashed or to get the bike over to a dyno.
    That all said, there are some DIY's to bypass the O2 and EXUP. I'm more curious about gaining the ability to get into the ECU from a laptop
    WMC original sdog30's Avatar
    Burgy
    Re: Questions regarding 2012 R6
    Tuneecu.
    Your better off buying a bazzaz fuel commander though. Then you can get rid of the light and upload maps and get a quick shifter.
    LRRS/CCS #66
    Tuneecu.
    You can do a quick shifter with the stock ecu...
    Burgy
    True. With Tune Ecu reflash. There were a couple guys on here that used to do for people. Not sure they still do though.
    I seem to remember my 09 had an engine light on from the full Akro exhaust and it didn't affect anything running wise.
    LRRS/CCS #66
    Burgy
    Pm Rich (tropicoz) he flashed mine for me. I can't remember if he still has the set up or not.
    LRRS/CCS #66
    Bike has Bazzaz QS 4 so it's already setup with QS. There are also a total of 3 ECU's that are included with the sale so maybe one of those is already setup to eliminate the CEL.
    Seems TuneECU for Windows is NLA. I'll look into the newer Android-based version this evening.
    If you have any running and or power issues, look to eliminate the bazaaz before chasing your tail. It's almost always the bazaaz. I removed mine and got a healtech quickshifter. simple and bulletproof.
    Burgy
    The bazzaz is definitely the nicer of the two between dynojet, imo. Sounds like you have everything you need though. It's pretty amazing what you can do with just the ecu. Bazzaz makes it a little easier to access though.
    Check the t fittings those things cause problems all the time. They aren't properly pierced through the wire sheathing or they loosen. That z125 I bought wouldn't start because of a poor connection through a t fitting at the throttle sensor. Once I wiggled the wire, started right up. Just solder ask the connections.
    Pretty sure there is a way to read and reset engine codes with bazzaz software though.
    LRRS/CCS #66
    You can send it over to Bauce Racing and he can flash it for you.
    Make sure the block off plates were installed.
    Here's a how to to make the bypass.
    https://www.r6-forum.com/threads/how...-06-r6.167193/
    Assuming it's only the EXUP, on both of my Yamaha's (R6 and WR250R) I had to buy an EXUP eliminator to plug in and remove the CEL with the aftermarket exhuast. There's also a way to do it with simple 'n cheap resistors. I went the power commander route on both so not sure how to get into the ECU or if you can even disable it that way.
    skip all that BS and ship your ECU to Bauce Racing in NJ
    Better yet, just bring it there for a dyno session. You won't regret it.
    Burgy
    Markbuilt
    LRRS/CCS #66
    Lifer FirstDuc-1098's Avatar
    Central Mass
    You guys are all missing the important question, does this mean Bergs is back racing this year?!? And on an R6!?!
    Shit Corey says:
    Burgy
    I have info...but I was sworn to secrecy. Although that info was regarding the fz6, but I have a feeling it might also apply to said r6.
    LRRS/CCS #66
    Trackdays for now.
    Posting Freak Gecko's Avatar
    Jul 2008
    Markbuilt
    John
    CCS/LRRS Expert #69
    LRRS Rookie of the Year 2004
    No turning back now! Bike gets picked up in CA on Friday then travels East to a loving home. Of course, timing being everything, soon after I committed to the seller, an R6 becomes available locally. Because, of course it does...
    Burgy
    Rain bike? Lol
    LRRS/CCS #66
    Not of I want to live to ride the one that's coming in!
    Oh and side note, the bill of lading should be printed and ready for when the driver arrives to pick up.
    Pickup rescheduled for Monday.
    Behold the Nimbus 2000!
    Questions regarding 2012 R6-img_20220223_165815641-jpg
    7 Not allowed! Not allowed!
    Burgy
    Looks pretty clean.
    Couple cans of flat black krylon fusion, frame and spool sliders and some engine cases and you are all set to go.
    LRRS/CCS #66
    It's actually remarkably clean. I was surprised once I pulled it off the skid and started hanging the body work.
    Clutch side has a Woodcraft cover but yes, sliders are a must.
    I finally have an answer to the CEL as well, error 17 for
    EXUP motor open or shorted....in other words, removed hardware but not bypassed electrically.
    It came with 2 spare ECU's so I may swap those to see if the CEL goes away.
    Burgy
    Fuck the exup valve. Added weight. That Akro is a nice set up, even if it is rashed a little.
    LRRS/CCS #66
    EXUP hardware is already out. With a few capacitors and resistors, I'll do some soldering to make the ECU happy.
    As far as the rashed Akra, it's mostly on the end cap so I'll see about sourcing a replacement if Akra has them available.
    The sale also included a full Ti Arrow system along with a bunch of other items....Woodcraft digi warmers, a pair of Pit Bull stands, gearing, levers, clip ons... basically a decent starter kit for someone who might be interested in getting back into racing, for example
  1. RRR 2012: Random Rhode island Rides for 2012 thread
    By FriskyDingo in forum Rides & Events
    Last Post: 09-03-12, 11:56 AM
  2. KTM LC questions
    By SVRACER01 in forum General Bike Related
    Last Post: 01-30-12, 05:35 PM
  3. Hi, few Questions
    By murfthesmurph in forum General Bike Related
    Last Post: 05-31-06, 10:04 PM
