3
I am getting out of racing and hate to see this bike just sit. Price at end of list.
Very good bike handles great almost telepathic
I have not hit the deck with this one.
Has used Pirelli slicks Fronts got a season on it, Rears got a barber practice and one race
Should replace the belts. Just because it been two years
Not used a lot in the last two years. Maybe 10/12 races/practices in that time.
Valves should be good
Last adjustment was done at Clubhouse two years ago.
Oil changed often.
Engine:
2000 748 with 916 pistons and cylinders. All rockers and valves that were bad at this time where replace when the kit was installed.
Stock heads, cams and bottom end.
Stock injectors
996 oil cooler upgrade
Chipped ecu believe it’s a ferracci.
Bike dynode at 95hp have sheet somewhere
Clubhouse did the install and dyno
Samco silicone Tube kit in blue. Bike runs cool.
Stock wiring harness not cut everything street was pulled at connectors
Frame:
Stock 99 with adjustable steering head
Mag/alum? rear mono sub frame
Carbon air box and intake runners
Carbon heal and exhaust guards
Lg single air filter over injectors
Marchesini mag front wheel
848 stock rear the lightest stock rear you can find
520 gearing
20mm Penske kit in forks
Penske Triple adjust rear
DP pads
Quick change rear sprocket
Brembo 18-20 front master
Cycle cat rear sets right side shortened bought them that way
Lightened vented clutch cover
45mm Terignoni carbon slip-ons
Stock headers
Shark skin body work in fair usable shape, paints rattle can.
Tanks mint not rattle can
Speedo removed
Tach, water temp gauges remain added oil and neutral lights
Aluminum fairing stay
Spares:
Stock set of five spoke Marchesini sliver/gray wheels with front rotors prefect
Stock airbox and runners
Stock subframes (2)
A full set of street body work After mkt. in better then good shape
Stock three spoke front wheel straight with rotors
Spare rear sets and gear shifter
GP shifter
Spare rear sprockets some still in pkg. new.
Spare clutch plates
And anything else I can find that fits this bike
Price just the bike alone $4250.00
If you want everything above $5500.00
Building mine into an 853 for this season lol what was your best time at nhms? Is either spare subframe allow/mag? Any race nose fairings?
On this bike at 64 years old I did 1:20s might have done a high 19s. Both spare sub frames are stock alum and buy my bike you will save a lot of money building yours!
If those are actually aluminum not steel id be interested in buying one. Ill pm you as well. Lol and way to wait to save any money now
sorry their steel not sure what I was thinking.
Roger that thanks for checking.
Ha, not surprised to see this listed here. to answer your question Duffy, I raced a 748/853 in the early 2000's and got down to 1:17's, more consistently in the 18-19's, as a middling Expert around the time. Seems high teens are well within the limits of the platform, and mid- or low- teens if you're proper fast. I think Brett Guyer recently raced his 748 no? Unsure of his times but he's quick AF.
Appreciate the response to that, gives me some hope lol
Just throwing it out there... got a really nice 2016 Multi 1200 for sale. I would take this bike in partial trade.....
