Results 1 to 11 of 11
crf running like shit, need help
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Mt buddys '02 CRF 450 is running bad. (Has stock engine/exhaust.) When the bike gets hot it is stalling a lot, and it is a bitch to start. The bike stalls a lot when hitting ruts/bumps/roots. When he re-starts, it likes to stall if he gives it any throttle.
    The bike probably has 150 hours of trail riding on it. He pulled the carburetor, everything looks fine. He checked the valves, said they were within spec but 1 thou on the tight side of things.
    What should he check next?
    We are supposed to ride the Hatfield McCoy trails this weekend, so this is sorta fucking things up.
    Thanks, Todd
    Re: crf running like shit, need help
    The basics. Fuel and spark. Tank Vent one way valve, clean air filter, test coil, test stator, clean or replace kill switch.
    Do a compression check, even though the valves may be in spec, they are known for slowly failing. 150 hours is quite a bit in the dirtbike world.
    You are going to LOVE Hatfield & McCoy trails. What trailhead are you staying near?
    Apr 2006
    massachusetts
    We're staying near Bearwallow. The plan is to ride dirt for 3 or 4 days, then park the truck/trailer somewhere and ride streetbikes for a few days.
    This right here makes me think "running lean".
    You guys check for intake leaks?
    Apr 2006
    massachusetts
    yeah, we did. haven't checked the electrical end of things yet, we'll probably do that then check compression.
    Valves are too tight. Hot start problem is common with those. The early years they used sucky materials.
    Bearwallow is fast and fun
    Apr 2006
    massachusetts
    accelerator (sp?) pump circuit had some fudge in it, no fuel was making it out of the port.
    Glad you got it fixed. I'd still check out the valves and seats. Thats a lot of hours on a dirt bike.
    Lifer lrrs313's Avatar
    Asheville, NC
    Quote Originally Posted by med00F4 View Post
    Big +1. Pull head, have the valves, seats, etc. checked by someone who knows.
    -Brian
    15 S-Works Venge
  1. 09' R6 Running like sh!t
    By Fastsc92 in forum Bike Maintenance
    Last Post: 11-29-10, 09:52 AM
  2. running like shit. help!
    By mikeb in forum Bike Maintenance
    Last Post: 06-29-06, 10:31 AM
  3. running on the LE
    By Cowboyrider in forum General Bike Related
    Last Post: 06-28-06, 01:16 PM
