Page 8 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 176 to 200 of 446
Ice Ice baby
  1. #176
    Re: Ice Ice baby
    I might have to wrap myself with pillows. I had a hard enough time keeping standing when stopped on wet frozen leaves, nevermind actual ice.
    2016 BMW S1000XR
    Re: Ice Ice baby
    Put a cinder block out there to step on...
    Re: Ice Ice baby
    It's usually not a problem, but when it is, you bet someone will be nearby with a camera
    Yeah.
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Re: Ice Ice baby
    I'm thinking the same protection I wore when dropping into a half pipe on a skateboard after a twenty five year layoff: hockey pants and hockey elbow pads. (Motorcycle helmet)
  6. #181
    Re: Ice Ice baby
    Boot Studs.
    you just need the pockets for them.
    No pockets needed-
    Stainless Steel Slotted Hex Indented Head Sheet Metal Screw #8 x 3/8, Qty 100 | eBay
  7. #182
    Re: Ice Ice baby
    probably have safe ice by the end of the week, was 0 this morning and forecast not to go above freezing all week
  8. #183
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Re: Ice Ice baby
    Is it worth setting up an XR100 to do this or should I be buying something different? It seems like I should be getting tires and an extra set of rims so I'm not constantly swapping tires. It's already getting expensive. Why must I have so many expensive hobbies?
    LRRS 878 Clapped out Gixxah
  9. #184
    Re: Ice Ice baby
    so long as the Weather Underground forecast is correct and were only getting a 1-3" Alberta clipper tonite and not the 4-8" the snow monger forecasters are predicting, 8" of insulation on top of a thin layer of ice will be a disaster
  10. #185
    Re: Ice Ice baby
    Quote Originally Posted by wiggeywackyo View Post
    Kerry's xr150 is perhaps the most fun of all the bikes I've ridden on the ice as far as sideways lean angle goes... Just go for it.
    Re: Ice Ice baby
    if it were me because I'm cheap AF, I'd just stud your current knobbies if they're thick enough....otherwise I just saw a set of F&R XR80 rims sell for $70 + s&h on fleabay (which can double as faux sumo 16" rims w' bt45's)
    I can't imagine you'd use it so many times on ice that it's worth another $1,500 in bike + tires...2-3 times tops?
    is it not a much more powerful crf??
  12. #187
    Re: Ice Ice baby
    If you have the machine and the means.. I highly recommend.
    Ice riding is big fun.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    Re: Ice Ice baby
    Looks like I should be looking into ice tires for the TTR.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
  14. #189
    go faster cdovego's Avatar
    Weymouth
    Re: Ice Ice baby
    Damn right you should be, plan to spend your free time on the pond with us.
    Central Mass Powersports #123
  15. #190
    Re: Ice Ice baby
    its got to be cold enough now
  16. #191
    Re: Ice Ice baby
    Takes time. Water is very stable temperature wise. Takes a lot to freeze a large body of it. Plus, the ground needs to cool off. My basement is still warm. BUT I will be swapping tires starting this weekend!
    Re: Ice Ice baby
    It's not a good thing to rush. Ground is still not frozen now that it's insulated by snow.
  18. #193
    Re: Ice Ice baby
    Kerry's xr150 is perhaps the most fun of all the bikes I've ridden .
    well I'll be damned...
    2016 Honda XR 150L Dual Sport
    you guys have one of these??
  19. #194
    Re: Ice Ice baby
    No, just a regular XR. WHy ruin a play bike like that? lol
    Well, I successfully changed 1 of 4 ice tires today. I did pinch a tube so that took some extra work/time to replace. I'm getting better at it. My Rabaconda stand and their videos are so key. Since I have relatively little bodyweight, I would never try it without the rabaconda. I'm still a beginner at this, but I could see getting pretty damned quick using this thing. I really didn't even use lube and I stopped struggling and started using technique. By the time I get the 4th one on, I will no longer be a beginner.
    Re: Ice Ice baby
    Why wouldn't you use lube?!
    Hiram, ME
    Re: Ice Ice baby
    I remain steadfast that I will not mount my own ice tires. For now both bikes are fine, but if I need to replace any of them, I'll pay someone else to do it.
    Re: Ice Ice baby
    Hahaa. I'm gonna get really quick at it and charge 80 a set.
    Hiram, ME
    Re: Ice Ice baby
    I'd probably pay that.
    Re: Ice Ice baby
    I have, that's pretty much why I bought the rabaconda setup
    Hiram, ME
    Re: Ice Ice baby
    I should probably knock on wood, but since ice tires aren't something I expect to replace often, paying someone else to mount them on dedicated wheels is the easy way to go.
  1. Ice, Ice Baby!
    By Stoneman in forum Dirty Bastards
    Last Post: 03-08-11, 09:10 AM
