Results 51 to 75 of 96
How to remove frozen axle
  1. #51
    Jun 2005
    Re: How to remove frozen axle
    I am the walrus.
    He does not read.
    Paul, I'm a little disappointed we have yet to see pictures of this mauled axle.
    I'd be lying if I said I wasn't mildly freaked out by this. I go back and forth between a cheap set of wheels and the stock wheels all the time, and now I'm a little weirded.
    I can post up. I'm not sure pics do it any justice though. I would just keep an eye on the spacers for flaking or corrosion. Once it starts getting a little hard to remove the axle, replace them.
    Here's the axle and spacer. Both stock. 2 seasons on it.
    Also, typeone, it does look like my tire spun. The valve stem tore right out of the tube. That's a first for me. Rimlock was tight.
    Lifer ZX-12R's Avatar
    Candia, NH
    It's possible the tire stayed put and the tube moved inside it. I've never torn a stem off but I've gone to change tires where my valve stem is pointing at an angle which means something moved. I've never marked the tire and rim to see if it's the tire. I've debated running a second rim lock but never got around to installing one.
  6. #56
    No MO GAS! I must have been layin down too much power!
    but which way was it crooked? i thought i was spinning on accel as well but it was actually decel dragging brake down rocky hills.
    Eek hidden costs of dirty maintenance I am sure 95% of CL riders don't do
    95%? That's being generous!
    Paul, glad you got it fixed.
  9. #59
    Well. It was not a pinch flat at least...
    Haverhill, MA
    No patching that one to keep as a spare lol
    Candia, NH
    Sometimes you can tug the nips too hard.
  12. #62
    Ouch!
    It sure felt good to insert that axle and have it go all the way in with a smooth action...
    Lifer GMAN226's Avatar
    Coventry RI
    You have been known to use all the power
    Gerard
  14. #64
    Was any lube required
  15. #65
    I have decided natural is best. Lube plus sand equals cement paste.
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    How has no one turned the last two posts into something dirty.
  17. #67
    Lifer Stromper's Avatar
    Eastern Ct
    I guess I did miss that
    The calculus of hate
  18. #68
    I thought it was already obvious after the pull the nips comment...
    It was too easy...
    Jul 2014
    Central CT
    Easy or not... don't think I've ever seen this group miss an opportunity.
  21. #71
    Lifer Pittenger5's Avatar
    Austin
    I personally like them easy, but thats just me.
    Zip Tie Alley #505
  22. #72
    You disgust me.
    Austin
    You disgust me.
    PM sent
    Zip Tie Alley #505
  24. #74
    PM sent
    Lies.
    hmm, starting to suffer from this ... found corrosion on axle and spacers before Sun ride, i've never seen that before. rode through a few deep water crossings two rides before. crap. hadn't washed the bike so i know it was from those crossings.
    i'll clean up the axle and spacer for now, did it quickly Sat afternoon, but will prob upgrade to that SKF spacer/seal kit this winter.
  1. My Ducati is frozen solid
    By ranette in forum General Bike Related
    Last Post: 01-22-11, 11:48 AM
  2. Hello all from the frozen lakes in NH
    By smallcool1 in forum Welcome and Intro
    Last Post: 01-29-10, 02:54 PM
  3. Frozen Nuggets
    Last Post: 03-17-09, 09:14 PM
