1
It's possible the tire stayed put and the tube moved inside it. I've never torn a stem off but I've gone to change tires where my valve stem is pointing at an angle which means something moved. I've never marked the tire and rim to see if it's the tire. I've debated running a second rim lock but never got around to installing one.
but which way was it crooked? i thought i was spinning on accel as well but it was actually decel dragging brake down rocky hills.
No patching that one to keep as a spare lol
Sometimes you can tug the nips too hard.
Was any lube required
How has no one turned the last two posts into something dirty.
I guess I did miss that
The calculus of hate
It was too easy...
Easy or not... don't think I've ever seen this group miss an opportunity.
hmm, starting to suffer from this ... found corrosion on axle and spacers before Sun ride, i've never seen that before. rode through a few deep water crossings two rides before. crap. hadn't washed the bike so i know it was from those crossings.
i'll clean up the axle and spacer for now, did it quickly Sat afternoon, but will prob upgrade to that SKF spacer/seal kit this winter.
