I need to make the trip to RI one of these days to test out the gravity on Mark's property. Gotta see if it affects my bike the same as it seems to everyone else that rides there.
I was hurting today and that was one of the best riding workouts I'd had all season
You are doing great for a new rider and it may be time to take the lead for a change in pace for you? Besides, it's my turn to follow for a while and see some...hmmm, how to say...unexpected encounters?
The more I rode the single track section, the more I like it. Turns out to be just about a mile and the way it's set up now, it automatically doubles back on itself so it's really 2 miles. It needs to be ridden to form an easy to follow line, that's half the battle.
I'll be up for some trail work this weekend if you want, there's a few spots that need some TLC. That one rock garden you mentioned, there's a sink hole somewhere the size of a front wheel, and the big rock section needs some work.
Seems so far my neighbor is one of the only ones that doesn't suffer from this gravity issue...though he did tell a story about hitting a tree last weekend.
Anytime Joel, just let me know
If you're riding the clutch a lot and the bike is hot, it's pretty normal for the clutch to drag and "almost" not work. What people tell me the fix is, is to go faster
First things I'd do if the clutch was dragging, check the cable is not tight and binding anywhere. A little cable drag can cause a little clutch slip and heat it up. Also, change the oil and make sure the proper weight oil is in there, big difference in clutch feel with fresh oil IMO
I've no issues with used boots, possibly issues with cash flow but not with used gear. : )
It doesn't slam into gears, it actually clutchless shifts beautifully. It's that shift from neutral to first thats fun as I'd better be ready to move NOW, and you can actually break the rear loose by grabbing a handful in first while squeezing the clutch for dear life even when it's working at it's best.
I'm going to get a new cable ASAP as I noticed I went from almost no adjuster use to nearly all of the adjuster out not long into the day while trying to maintain proper freeplay. I'm going to pull the push rod and plates for inspection this weekend to make sure they're all in tact as I guess the push rod is known for deforming, and warped steels would certainly explain the symptoms also.
Also, check for notches in the fingers of the basket.
