Results 1 to 9 of 9
installing graphics
    installing graphics
    Man, do I suck at that! Anyway, I am no longer embarrassing the previous owner by running his numbers. I mixed and matched number plates from a different kit. Looks a little off, but not bad. Full kits are just too expensive. Not to mention how crappy it would look if I installed it! Lots of wrinkles and bubbles despite using water, etc.
    FYYFF theothersean's Avatar
    middle of nowhere
    Re: installing graphics
    you want to use soapy water , only a little bit of soap just enough to make it slip , spray it on the sticky surface then you can move the decal around into place and squeegee the liquid out from behind it ,use it in a spray bottle so you can spray it on the outside as well to minimize the friction on the decal itself when getting out all the air bubbles, little dab will do ya , let it dry before touching .
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Tried that. Well, I didn't use a spray bottle, but I put a drop of soap in the water. Couldn't exactly slide the decal around, but I could at least pull it back up to adjust. I just plain suck at it.
    middle of nowhere
    I use the same spray bottle I use to mount tires , you would be amazed what a little lube will do
    12 Vstrom 1000
    09 KLR 650
    (hers)
    13 Vstrom 650ADV
    09 KLR650
    Don't you guys know anything Windex and a hair drier and your decals will look factory installed
    Bike still looks great Paul
    looks good For crow hill Saturday?
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Leaving for Jersey sat. at noon. Sunday on thunderbolt, monday on Lightning. Woot!
    lookin' good!
    it is a tricky process, and pretty un-fun, i use similar method mentioned above...
    - remove old decals
    - clean plastic completely (contact cleaner is helpful)
    - wipe down with water
    - wipe down with rubbing alcohol
    - fill spray bottle with water, add a drop of dish soap, mix
    - spray plastic completely
    - spray back of decal completely
    - postion onto plastics, move around as needed
    - push bubbles from center out using a hard rubber or soft plastic squeegee
    - let dry
    - prick any air bubbles with a pin and squeegee
    live to ride seth399's Avatar
    Feb 2007
    CA
    looks good...I actually put mine on dry usually. Nerve-racking but I usually end up with a good job
    LRRS #399
    MX #505
  1. I need help with installing...
    By dipthat in forum General Bike Related
    Last Post: 06-03-10, 12:25 PM
  2. Help installing R6 exhaust
    By Kitt in forum Pit Area
    Last Post: 05-25-10, 12:34 PM
  3. Installing Clipons
    By spydah in forum Bike Maintenance
    Last Post: 07-24-08, 11:47 AM
  4. Installing Clip-ons
    Last Post: 04-13-05, 06:55 PM
