Results 1 to 5 of 5
Track Bike Maintenance Intervals
    Nov 2004
    Boston, MA
    So as my season ends I am giving more thought to needed upkeep and preventative work on my track bike.
    Im curious to know what I should be thinking about on a yearly or every other year basis etc.
    Particularly curious about intervals for shock rebuilds and fork oil, but also trying to think of anything that should be considered every few years that I wouldn't think of.....
    Im guessing I did about 1k or so track miles this year.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    KB KB's Avatar
    Manchester NH
    Re: Track Bike Maintenance Intervals
    Valve check/adjustment
    Fluids shock, brake, oil, clutch
    Chain and sprockets
    Air filter
    Check and gap plugs
    Sync carbs if so equipped
    Brake pads
    Stearing head bearing check
    Just an all around once over take off the fairings and get a good look at the thing.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer Expat's Avatar
    Mar 2007
    Chain and sprockets
    Air filter
    Check and gap plugs
    Brake pads
    +1, I also check / grease the shock linkage, disconnect and store the battery and I always replace the plugs rather than clean.
    Also, I usually wait until Feb so the bike doesn't sit too long without being run, that reduces the chance of condensation in the oil etc.
    High maintenance priss
    Central MA
    +1. I'd add:
    -Compression Test
    -Leakdown Test
    -TPS (if applicable)
    Just Registered Doc's Avatar
    Jericho, VT
    Wheel bearings? If they are stock.
    I think GMD would say fluids/rebuild of suspension yearly or by yearly on a racebike.
  1. Maintenance intervals
    Last Post: 06-07-13, 11:39 AM
  2. track tire pressure maintenance
    By Jayspeed in forum General Bike Related
    Last Post: 06-30-08, 04:26 PM
  3. Running at the track require different maintenance?
    Last Post: 10-11-07, 10:40 AM
  4. Bike maintenance's day?
    By MissTwisties in forum General Bike Related
    Last Post: 04-04-07, 06:29 PM
  5. Anyone need any bike maintenance?
    Last Post: 10-30-02, 09:08 AM
