Suzuki is set to debut a new SV 1000 and SV 1000S for 2003.
Motivation will come from the 996cc V-Twin engine once seen in Suzuki's TL1000S.
Fully adjustable 46mm forks suspend from a rigid aluminium vacuum-cast frame.
Braking is handled by 310mm discs up front with 310mm 4-piston calipers. A single 2-piston caliper works on a 220mm disc at the back.
More details later...
2003 Suzuki SV 1000S - Specifications
Engine - Liquid-cooled, 4-stroke, 2-cylinder, 90° V-twin, DOHC, 4 valves per cylinder
Bore x Stroke - 98.0 x 66.0 mm
Capacity - 996cc
Compression Ratio - 11.3:1
Induction - Fuel injection with 52mm throttle bodies
Gearbox - 6-speed, constant-mesh
Frame - Alumin0um-alloy truss frame
Front Suspension - 46mm forks, fully adjustable
Rear Suspension - Single shock with progressive linkage, 7-step adjustable preload
Front Brakes - 4-piston calipers, 310mm dual discs
Rear Brake - 2-piston caliper, 220mm disc
Tyres - 120/70ZR17 (F) - 180/55ZR17 (R)
Fuel Capacity - 17.0L
Length - 2,130mm
Width - 730mm for the S or 790mm
Height - 1,170mm for the S or 1,040mm
Wheelbase - 1,435mm
Ground Clearance - 140mm
Seat Height - 810mm
Dry Weight - 189kg for the S or 185kg
