Results 1 to 18 of 18
03 sv1000 & specs
    Lifer legalspeed's Avatar
    Somersworth, NH
    03 sv1000 & specs
    Suzuki is set to debut a new SV 1000 and SV 1000S for 2003.
    Motivation will come from the 996cc V-Twin engine once seen in Suzuki's TL1000S.
    Fully adjustable 46mm forks suspend from a rigid aluminium vacuum-cast frame.
    Braking is handled by 310mm discs up front with 310mm 4-piston calipers. A single 2-piston caliper works on a 220mm disc at the back.
    More details later...
    2003 Suzuki SV 1000S - Specifications
    Engine - Liquid-cooled, 4-stroke, 2-cylinder, 90 V-twin, DOHC, 4 valves per cylinder
    Bore x Stroke - 98.0 x 66.0 mm
    Capacity - 996cc
    Compression Ratio - 11.3:1
    Induction - Fuel injection with 52mm throttle bodies
    Gearbox - 6-speed, constant-mesh
    Frame - Alumin0um-alloy truss frame
    Front Suspension - 46mm forks, fully adjustable
    Rear Suspension - Single shock with progressive linkage, 7-step adjustable preload
    Front Brakes - 4-piston calipers, 310mm dual discs
    Rear Brake - 2-piston caliper, 220mm disc
    Tyres - 120/70ZR17 (F) - 180/55ZR17 (R)
    Fuel Capacity - 17.0L
    Length - 2,130mm
    Width - 730mm for the S or 790mm
    Height - 1,170mm for the S or 1,040mm
    Wheelbase - 1,435mm
    Ground Clearance - 140mm
    Seat Height - 810mm
    Dry Weight - 189kg for the S or 185kg
    LRRS\CCS\WERA #486
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    03 sv1000 & specs
    *DRIBBLE* *DROOL*
    want want want, lust lust lust
    damn, i wonder what the price on that bike is gonna be?
    Somersworth, NH
    03 sv1000 & specs
    Does anyone know how to keep the image from pixilating when reducing?
    --And/Or--
    Anyone know how to cheat "The Man" and post a large image?
    LRRS\CCS\WERA #486
    ultrabuddy twrayinma's Avatar
    Apr 2002
    albukoikee
    03 sv1000 & specs
    all i *really* want for christmas is for those mirrors to be a bolt-on replacement for the early SVS models...
    -t
    Northshore/Beverly, MA
    03 sv1000 & specs
    Here's the side view....
    Somersworth, NH
    03 sv1000 & specs
    t',
    Suzuki re-uses parts. My Katana shares many parts with the 1k, the engine NOT being one of them.
    The 02+ 1k's mirrors may fit your SV as well.
    Thanks Mark!
    I must say that machine is purdy. I like the way the truss design is mirrored in it's radiator.
    LRRS\CCS\WERA #486
    Apr 2002
    albukoikee
    03 sv1000 & specs
    ps. crim... did you miss it when i posted the pics here?
    Lifer SEVENSGT's Avatar
    Warwick, RI
    03 sv1000 & specs
    That settles it the Hawk is goin goin gone, I want an SV1000S, the only thing holding me back was TW didn't show the 1000S model
    Apr 2002
    albukoikee
    03 sv1000 & specs
    it was right below the naked one.
    sheesh.
    Warwick, RI
    Talking 03 sv1000 & specs
    Hey TW, how come eveyone calls you RAY?????????
    03 sv1000 & specs
    yes, even the SV650 shares some parts with the Katana, wheels, fork springs etc. I think almost all Suzuki sportbikes use the same shifter & rear brake pedal.
    What is surprising is how many jap bikes have standard fasteners & controls, The KLR650 handguards I put on my SV, bolted on almost as it they were made for the SV
    I'd still rather have a DL1000 even if the SV1000 becomes available in the US. I think the SV1000 defeats the reason the SV650 is such a hoot to ride, so what its got 50% more horsepower, it also weights 40-45 lbs more. I think they oughta bring the SV400 to the US also
    Apr 2002
    albukoikee
    03 sv1000 & specs
    beats the fuck outta me, man...
    why you call me TW?
    i could break down the etymology of my arcane screenname, but that would be, like, complicated and shit.
    -t
    Somersworth, NH
    03 sv1000 & specs
    T', I think your pics are photoshopped, most are just red x's now.
    Notice the wind screen area.
    I think Randy said it: will they bring it to the US market?
    LRRS\CCS\WERA #486
    Oct 2001
    Bedford, MA
    03 sv1000 & specs
    It sounds like the SV400 isn't particularly great as a 400, it's supposed to just be a de-stroked 650 minus one of the front disk brakes.
    So it would be heavier than a bike designed to be a 400, etc..
    As for the SV1000, it seems like they're just trying to throw a bone at all the SV650 fans, that bike sure seems like it would be called the next-gen TL1000S if the SV650 wasn't popular.
    Ben
    03 sv1000 & specs
    Just looks like a revamped TL-S to me. Is it just coincidence then that the first genre TL-S were technically named the TL1000SV? Hmmmm....
    Apr 2002
    albukoikee
    03 sv1000 & specs
    Originally posted by criminalspeed
    [B]T', I think your pics are photoshopped, most are just red x's now.
    ah the perils of linking your pics from another site...
    that isn't in english...
    *shrug*
    Warwick, RI
    03 sv1000 & specs
    why you call me TW?
    -t
    Beets the fuck outta me too, I mean fuck TW???
    Walpole
    03 sv1000 & specs
    It does look sweet. And quite a bit like the TL....funny it has the TL motor eh...
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
  1. Wanted - Parts & Tools | GSXR or SV1000 wheels (01-04 GSXR 1000 or 01-05 GSXR 600/750 or any SV1000 )
    By juha_teuvonnen in forum Wanted
    Last Post: 08-24-15, 12:25 AM
  2. Specs of metal in oil
    By Petorius in forum Bike Maintenance
    Last Post: 07-27-14, 05:40 PM
  3. Torque specs please
    By Fitz in forum Bike Maintenance
    Last Post: 07-06-08, 06:05 PM
  4. Bike test box specs
    Last Post: 07-30-07, 08:46 AM
  5. 03 1k front and specs...
    By legalspeed in forum General Bike Related
    Last Post: 09-17-02, 08:05 PM
