Results 1 to 25 of 34
RC8R valv stem ruined
    TWINS! xrocket21's Avatar
    Central Maine
    Schrader valve was stuck, tried to remove it, broke off half way
    Never changed a valve stem before, think these will work?
    https://www.amazon.com/VTR-TR-416-S-...s%2C137&sr=8-8
    Re: RC8R valv stem ruined
    They likely will, you'll want to find out the size of the hole in your rim just to be sure, but those should.
    I like putting in the 90° ones to make pressure checks/adjustments easier.
    +1 on checking sizing and i'd maybe look for a bit higher quality stem, the metal looks iffy on those. not sure what the OEM RC8 stems are like but should be an easy swap. wild it snapped.
    also agree on 90°.
    Dublin, NH
    You should probably know the valve stem hole size before ordering anything. Seems like most motorcycles are 8.5mm/11.5mm F/R? Something like this might be a better fit and more convenient.
    2023 KTM 890 Adventure R
    Central Maine
    oh yeah, its a nice bike, Im all for getting nicer valve stems. A friend has a tire machine, so we can break the bead and just swap the stem without even removing the tire we are hoping. I DO NOT want to scratch those orange Marchenesi wheels...
    what I got out vs what a normal one looks like.
    I was hoping motorcycles were a standard size, Ill have to figure out what size hole it is. I want to have one here before the weekend.
    note the green, I think it was fix a flatted at one time
    Central Maine
    of course the fiche dont show the valve
    https://www.motosport.com/oem-parts/...el?fam=chassis
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    I'd guess it's an 8.3mm as that's what most of my non-Japanese bikes are. Or at least my Triumphs. I've gotten to the point where I just keep a small stash of both 8.3mm and 11.3mm 90 degree valve stems on hand. I'd just buy them both and hold onto/gift/return the one you don't need.
    Central Maine
    This was in the middle of replacing the grill on my truck, needed a part from the store, took the EXCf, that has a CEL, store didnt have the part, came back to get the RC8r to go to a further town, got half my snowmobile gear on, kicked the tire last minute to check air, needed air, then the schrader valve is stuck..... It was one of THOSE fuckin days, boys
    holland ma.
    Make sure you get the little tool to help pull it through. use lube to pull it through too. Personally i just use the all rubber ones. I have never had one fail. No need to try and bling out what no one will see. Can you imagine that nut backing off in the middle of maine? Your bumming.
    Central Maine
    I do have the little tool, since I have been doing a bunch of dirtbike tires these days
    I will probably cry if the wheels get scratched
    Lifer ilikenapalm's Avatar
    Connecticut
    I have no idea how you're going to install a stem without removing the tire, but major props if you pull it off.
    Central Maine
    Quote Originally Posted by ilikenapalm View Post
    you dont think we can squish the tire back enough to get a hand in there?
    Yeah, pinch the tire with a large C-clamp. Done it before.
    Dublin, NH
    The two piece types are actually easier than the rubber stems since you don't need to pull it through. Just pop the beads to get them in the drop center and you'll have plenty of room to work. Worst case you can use a stem puller tool like this to fish it back in.
    Central Maine
    And I have that stem puller tool
    Aug 2012
    LA
    Rear tire is easy to squish and replace valve stem.
    I've never heard of this happening and has never been a concern of mine. 65k miles without issue on my Tiger, maybe 150k on all of my bikes combined, and I ride to some pretty remote locations.
    holland ma.
    It happens on my nsr. I assume because it's a buzzy machine I beat to near death every time I start it plus 30 year old rims.. It has a weird Honda metric rim that uses those nutted on valve stems. It become such a pain I just put tubes in it.
    IMO, that green gunk is moisture causing the copper within the metal to oxidize.
    Flat repair products like Fix-a-flat have cotton (or cotton-like) strands mixed into the liquid which helps seal the puncture. You'd be seeing those strands all in that valve stem core if such a product were used at some point.
    Senior Member marshdrummer's Avatar
    Nov 2006
    Southington, CT
    You don't want a metal valve stem. You want aluminum. These will work perfectly and track tried and true.
    https://www.motodracing.com/moto-d-a...CABEgI6zfD_BwE
    Super easy to install.
    Lifer ZX-12R's Avatar
    Candia, NH
    Could you use a small left handed drill bit to grab the rest of the valve out of the stem?
    Central Maine
    Not sure what's left in there. What came out was a mess though
    Central Maine
    Quote Originally Posted by marshdrummer View Post
    Ahhh crap
    Hypertarded
    RI / CT border
    ...... I want to have one here before the weekend......
    looking like you may have some additional time to get that new stem.....
    Central Maine
    Lol, not to ride, but because I'm heading down to use a friends bead breaker
    Feb 2011
    Somerville MA
    Oof, fukken brutal. Bluer skies ahead I hope.
    -Jared
