Results 1 to 5 of 5
Brakes/head bearings
    Jun 2005
    Can the hot weather make the front brakes feel a little squishy? also, how can you tell if your head bearings are just slightly loose, without dismantleing anything?
    Atlanta, GA
    1) No unless its hot enough to boil the brake fluid
    2) Call Peter Kates
    Andrew
    03 Suzuki SV650
    Lost in my own mind... 01YZF6's Avatar
    Mount Washington, NH / Stowe, VT
    1. no the heat wont make your brakes feel squishy, but air int he line, fluid leak, or a bad brake hose will
    2. stand in front of the bikewith someone sitting on the seat to keep the bike stable.
    grab the hand grips and pull back and forth on the bars and feel if there is any play. ( ever had to tighten up the upper/lower fork nuts on a bicycle? it feels similar but takes alot more force)
    Dec 2003
    Ma
    Your head bearings are probably effed. I'd get your valves done at the same time while they're in there, and you should replace your brake pads and rotors.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    If head clunks when brakes are hit even when rocking the bike from and back.
    Before you go off on your brakes; solvent clean your rotors and maybe a little bleed
    Glen Beck is John the Baptist
  1. Wheel bearings?
    By nick5446 in forum Bike Maintenance
    Last Post: 02-13-18, 09:10 AM
  2. How to replace steering head bearings
    By kumpy in forum Bike Maintenance
    Last Post: 01-13-13, 08:57 AM
  3. Bearings
    By hondarider102 in forum General Bike Related
    Last Post: 03-10-10, 10:31 AM
  4. Steering head bearings are too easy...
    Last Post: 07-14-03, 09:39 AM
  5. Steering Head Bearings - 96 EX500
    By VinceF2 in forum Bike Maintenance
    Last Post: 07-15-02, 08:50 AM
