Results 1 to 15 of 15
Battery Tender Vs BT Jr.
    Work U HBerry's Avatar
    Nashua
    Is it worth it for me to spend the extra money for a normal Battery Tender? Or can I be cheap and just get a Battery Tender Jr.?
    TELL ME TELL ME TELL ME!
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Oct 2001
    Bedford, MA
    Battery Tender Jr. has been working great for me for 3 years now...
    I think all you get out of the big one is the ability to use it on a car battery and/or different voltage settings. The Junior model is the right voltage for a bike.
    BTW you should be able to get the junior for $20-30 if you're lucky.
    Nashua
    Because I'm stupid/too lazy too look it up, do I need the 6V or 12V version?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    You will need two 6v ones.
    -Clayton
    2006 Suzuki SV650
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    12v...all cars and bikes are 12v...only like older VW bugs etc..are 6v...
    Posting Freak patricia929's Avatar
    Aug 2003
    Kensington, NH
    arizona motorsports http://www.azmotorsports.com/
    is selling the battery tender jr for $19.95 so we just picked up a couple. not sure how well they work yet but i'm sure they're fine.
    the only normal people are the ones you don't know very well.
    clack clack Ducrappy's Avatar
    Feb 2004
    New Ipswich, NH
    It was explained to me by the parts guy at my dealer that the Battery Tender Junior is intended for bikes, and the Battery Tender (Original) is intended for cars.
    I've been using the Battery Tender Junior for over a year now. Most will suggest to pull the battery out of the bike and hook it up to the Battery Tender for the winter, but I've had great luck with simply installing the Battery Tender wiring directly to the terminals with the battery still installed in the bike. That way, if I don't ride for a few weeks, my battery will be fully charged.
    you seem to be related to nikon. so fuckyou too! go suck a cock./1
    2012 R1200GS Rallye
    Member Matt's Avatar
    Nov 2002
    In a van down by the rivah
    I've used a BT Jr. for 3 years now and they work great. I just plug it in when it's going to sit for more than a couple weeks. So far, so good.
    -Matt
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    CHEAP CHEAP CHEAP
    MY DRZ 400 is on a battery tender junior as I fear being in a swamp with no kick starter
    However I am trying red chinese technology
    Harbor frieght has float charger for
    $ 7.50
    I have 4 batteries to season over so ain't spending $130 for battery tenders
    Also ultracheap has worked fine for 4 years. Security light timer and 1 amp charger (no purchase required) I set it up to charge YZF battery for 15 minutes everyday
    PS In case its lost in grandpa stories If you charge a brand new battery with a 1 amp charge for a day before using it you will almost double its life. This is as opposed to slapping it in a vehicle and driving off. A high initial charge is supposed to damage the plate surfaces
    Glen Beck is John the Baptist
    Super Moderator legalspeed's Avatar
    Somersworth, NH
    Originally posted by richw
    CHEAP CHEAP CHEAP
    $ 7.50
    Right on.
    I bought a BTJr. at VIP for $16.95 (before these words of wisdom were bestowed upon us).
    LRRS\CCS\WERA #486
    Nashua
    Well I picked one up for 26.50 shipped following patricia929 advice. It should hopefully be here next week and I can throw my battery on the charger for the winter. Do any of you have the SAE connection hooked directly up to your battery and you leave it in there year round. If so where did you mount the SAE connection so it doesnt flop around when you ride?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Nov 2002
    My BT Jr connector is direct to the battery with a 25 amp fuse on it. It sits under my seat in that "storage compartment" (year round) that is only big enough to hold a pack of smokes.
    -Matt
    Feb 2004
    New Ipswich, NH
    As I stated before, I always leave the connector on my battery. It is a fairly short cable (Maybe a foot long or so). On my 996S, the battery was on the right side, just behind the vent in the plastic, so when I wasn't using the connector, I would just stuff it in between the plastic and the battery, and when using it, I would pull it out of the vent and plug it in.
    On my current bike, the battery is under the gas tank. I left most of the cable slack in a small area above the battery, and ran the cable down the frame to just above the clutch housing and this works great for me because the bike already has rubber ties on the frame to hold all of its wiring neatly. I just ran the battery tender cable through these rubber wire stays.
    2012 R1200GS Rallye
    I have a coupla automatic chargers that I use for everything. Paid like, $20 each at some McAutoparts chain. One of 'em I've had for years, the other is just a coupla years old. During the summer, I keep one permanently connected to my RV's auxilary battery. During the winter, I have the RV's batteries (the main one too), the Corvette battery, and the bikes' batteries (boat too, when we had it) alternating on 'em. Once in a while, I'll toss a charge on the big truck if it's really cold and it hasn't been driven in a while...
    I've had outstanding results. I hafta replace the RV's battery every 2-3 years, but the rest have held up well. My bike's still got it's original battery, the truck's is about 5 years old, replaced the Corvette's when we bought it 3 years ago, the main battery in the RV was in it when we bought it 2 years ago...
    The Battery Tenders used to be kinda silly priced, which is why I went with the basic automatic chargers...
    Aug 2004
    Baltic,CT
    Frugel me
    frugel me
    I applaud your value
    :hellyea:
  1. Battery Tender ?
    By Punjistick in forum General Bike Related
    Last Post: 01-20-07, 04:55 PM
  2. Battery...
    By Stoneman in forum Bike Maintenance
    Last Post: 09-16-05, 07:12 AM
  3. BAttery Tender
    By snaggle in forum Off-Topic
    Last Post: 01-31-05, 11:37 AM
  4. Battery
    By SVGirl in forum General Bike Related
    Last Post: 02-25-04, 04:33 PM
